Oil Pump Question
JPSmit
1500 engine
Can you spot the difference? does it matter?
aeronca65t
Yes. The difference is huge.
One pump is from a 1500 Midget and one from a 1500 Spitfire.
The difference (in pickup position) is created because the 1500 Midget oil pan was redesigned to clear the Midget frame members (the 1500 engine was used in the Spitfire first).
A Spitfire oil pump will fit under a Midget oil pan, but every time you step on the brakes or take a turn (even gently) you'll have no oil pressure. Ask me how I know!
JPSmit
JPSmit
So, I have to presume the angled pickup is the Spit?
I can exchange it - (the shiny one is the new one) - The new casting is much lighter - would it be worth simply swapping out the guts or the pickup?
thanks!
G
You'd swap endplates after honing on a piece of glass or mirror with fine/extrafine sandpaper. 240/320 to knock it down a bit(depending on how bad it is), then 400, 600 sometimes I go to 1200 if I have some laying around.
What are the specs of your old pump? Mine was still good.
JPSmit
JPSmit
So, if I can resurect this thread for a minute, I sent my Moss Vendor ( whom I trust a lot!) a question about the two different shaped oil pumps and this was his reply.
"The 2 pumps are interchangeable. The later angled pick-up is more efficient and prevents oil starvation on corners. Either type will work." This does not seem to agree with earlier comments. Can anyone confirm or deny? (With expertise :smile: )
thanks!
recordsj
I have the angled oil pump in my 1500 midget and haven't seen issues with loosing oil pressure when turning or braking.
Morris
I am rusty on this... so correct me if I am wrong...
The angled pickup is the correct pump. The straight pump was used in some early Midgets, but changed out for the angled pump in later years. I think even the spits abandoned the straight pump for the last few years. The pump that came in my '79 was angled, but I had a '76 spit donor engine that had the straight.
Nial does not specify which is which in his response, but hopefully he will come along and set us all straight. I defer to his expertise.
aeronca65t
The straight pickup is used on Midget. The angled pickup is used on Spits (because the oil pan is a completely different shape). Years ago, I got things mixed up and accidently put an angled-pickup pump into my 1500 Midget street car. Oil pressure would drop to zero when using brakes or certain turns (I forget which way). I put the correct, straight pickup version in the car and problem was solved.
Morris
Well there you have it. I had it backwards. I am pretty sure I am running the angled pump in my car. Which ever engine the straight pump came from, it was too trashed to reuse. I do not have oil starvation issues as long as I keep things topped up. If I let the oil get really low (a full quart), I will occasionally get the light of doom during braking on a down hill.
Nail, you didn't baffle you oil pan for a race car? :cool-new:
aeronca65t
No Hap. The 1275 isn't that way either. I should probably baffle my current pan at some point......I just haven't gotten around to doing any of that sort of stuff. When it comes down to it, my race car is really pretty stock in most ways. On the other hand, it'll spend 7 weekends racing in '13, which is probably more than a lot of racers. :friendly_wink:
D TR2/3/3A Oil pump question Triumph 31
JPSmit Question One - oil pump Spridgets 2
D Not another oil pump question. Austin Healey 7
B Overdrive Oil Pump Installation Question Austin Healey 10
DNK Oil Pump spin up Question Triumph 18
glemon TR5/TR250 TR250 Oil Pump Question Triumph 2
Morris Oil pump question Spridgets 1
jlaird Question-oil pump Spridgets 2
jlaird Question, Oil pump Spridgets 4
S got a wierd oil pump question. Spridgets 0
R Oil Pump Question Austin Healey 4
D Transmission oil pump question MG 2
KVH General Tech Oil Pump Woodruff Key Triumph 10
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
S For Sale Oil Pump Rotor Assembly for Sale Triumph Classifieds 0
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
A T-Series MGTD oil pump bypass valve MG 0
MikeAH100M Oil Pump for BN2 Austin Healey 4
A T-Series Mgtd oil pump alterations MG 2
nichola TR6 Oil pump drive barely engages Triumph 2
S TR6 After I put in my new oil pump.... Triumph 3
S T-Series oil pump MG 0
svtmikey GT6 Oil Pump replacement Triumph 5
J TR2/3/3A Oil Pump Wear Triumph 5
H For Sale Healey oil pump drive Austin Healey Classifieds 0
B TR2/3/3A Oil pump rebuild Triumph 4
Michael Oritt 100 Oil Pump--options and resources Austin Healey 12
Michael Oritt 100 oil pump Austin Healey 5
J Bj8 Oil Pump Austin Healey 2
J 3000 bj8 Oil Pump Austin Healey 38
Jim_Gruber Priming oil pump Spridgets 9
F Video showing oil pump and Kingpin bushing repacement on BJ8 Austin Healey 3
JPSmit New Oil Pump startup Spridgets 8
Rut 1275 oil pump, camshaft adapter Spridgets 2
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
gbtr6 TR6 Prime oil pump in rebuilt engine... Triumph 10
T TR2/3/3A Oil Pump Grief Triumph 8
tinman58 TR5/TR250 OIL PUMP Priming Triumph 3
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
dcoplan I've got a twisted camshaft-to-oil pump pin. How to fix?? Spridgets 1
BOBBYR oil pump choice Austin Healey 5
RJS TR4/4A Oil leak at/on fuel pump Triumph 7
D Wedge Funny oil pump Triumph 9
johnrip Wedge TR7 Oil Pump Leak Triumph 2
B TR2/3/3A oil pump drive shaft removal challenge on TR3 Triumph 14
Patrick67BJ8 Oil Pump Recommendation[s] for BJ8 Austin Healey 12
M Healey 100-4 Oil Pump Condition Check Austin Healey 3
BillW103 Oil Pump Spridgets 24
TulsaFred Oil pump priming access Spridgets 8
richberman Anyone rebuild oil pump gears Austin Healey 1
