Oil Pump Question
Ray Smith
I have two questions:
1. Can the rotor type pump be used in a BJ7 engine?
2. Which is more desirable, the gear type or the rotor type?
Thanks,
Ray
[ QUOTE ]
Thanks,
Ray
[/ QUOTE ]
1. Yes
2. Depends on who you ask; the factory updated to the gear type, but the guys at Southern Carburettors (now SC Austin-Healey) recommended the rotor type for my modified engine.
Given the pump being in good condition (no excessive clearance issues), either is good for a street engine.
AndrewMawson
[ QUOTE ]
Thanks,
Ray
[/ QUOTE ]
Call me a cynic, but I strongly suspect that BMC changed from the rotor type pump to the gear one as it was cheaper to make.
I was suffering low hot oil pressure on my BJ8 - I pulled the gear pump, and apart from very marginal scoring on the pump cavity walls it measured 'good' to the workshop manual spec using feeler gauges. I replaced it with a rotor type, and all my oil pressure issues went away.
I think that the rotor type actually displace more oil per rev than the gear type, but the gear type displace 'enough' for a new tight engine. I have no idea how many miles my engine has done since a rebuild but it must be well run in by now.
/ubbthreads/images/graemlins/england.gif /ubbthreads/images/graemlins/england.gif /ubbthreads/images/graemlins/england.gif /ubbthreads/images/graemlins/england.gif
Healey 100
My 100 has "suffered" from low hot oil pressure since I put it together thirty years ago. On a hot engine at 2500 rpm or so, it runs about 25 psi, give or take a few. At idle it drops to below 10. I use 20W 50 oil in it most of the time.
My engine has an original gear type pump that I checked for wear and it measured up as I recall. The main and rod bearings were new on this car 30 years ago, with nominal clearances on a newly ground crank. The rocker shaft is in very good shape.
I have driven this car thousands of miles in very hot weather with this low oil pressure with no problems at all that I can see. I am sure that a higher capacity pump would increase the oil pressure, but is it necessary? Remember that higher flow of oil through the bearings will also increase runoff from the bearings, especially the rear main which tends to leak like crazy from a 100. Ditto for flow up into the head, which has limited pathways for return back into the case.
I know it feels good to see 50 psi on that gage all the time, but is it really necessary? I would be reluctant to fool with a high capacity pump unless I was racing or had some sort of lubrication problem that was known to be caused by low oil flow.
Good luck!
Bill.
D TR2/3/3A Oil pump question Triumph 31
JPSmit Question One - oil pump Spridgets 2
D Not another oil pump question. Austin Healey 7
B Overdrive Oil Pump Installation Question Austin Healey 10
JPSmit Oil Pump Question Spridgets 13
DNK Oil Pump spin up Question Triumph 18
glemon TR5/TR250 TR250 Oil Pump Question Triumph 2
Morris Oil pump question Spridgets 1
jlaird Question-oil pump Spridgets 2
jlaird Question, Oil pump Spridgets 4
S got a wierd oil pump question. Spridgets 0
D Transmission oil pump question MG 2
KVH General Tech Oil Pump Woodruff Key Triumph 10
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
S For Sale Oil Pump Rotor Assembly for Sale Triumph Classifieds 0
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
A T-Series MGTD oil pump bypass valve MG 0
MikeAH100M Oil Pump for BN2 Austin Healey 4
A T-Series Mgtd oil pump alterations MG 2
nichola TR6 Oil pump drive barely engages Triumph 2
S TR6 After I put in my new oil pump.... Triumph 3
S T-Series oil pump MG 0
svtmikey GT6 Oil Pump replacement Triumph 5
J TR2/3/3A Oil Pump Wear Triumph 5
H For Sale Healey oil pump drive Austin Healey Classifieds 0
B TR2/3/3A Oil pump rebuild Triumph 4
Michael Oritt 100 Oil Pump--options and resources Austin Healey 12
Michael Oritt 100 oil pump Austin Healey 5
J Bj8 Oil Pump Austin Healey 2
J 3000 bj8 Oil Pump Austin Healey 38
Jim_Gruber Priming oil pump Spridgets 9
F Video showing oil pump and Kingpin bushing repacement on BJ8 Austin Healey 3
JPSmit New Oil Pump startup Spridgets 8
Rut 1275 oil pump, camshaft adapter Spridgets 2
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
gbtr6 TR6 Prime oil pump in rebuilt engine... Triumph 10
T TR2/3/3A Oil Pump Grief Triumph 8
tinman58 TR5/TR250 OIL PUMP Priming Triumph 3
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
dcoplan I've got a twisted camshaft-to-oil pump pin. How to fix?? Spridgets 1
BOBBYR oil pump choice Austin Healey 5
RJS TR4/4A Oil leak at/on fuel pump Triumph 7
D Wedge Funny oil pump Triumph 9
johnrip Wedge TR7 Oil Pump Leak Triumph 2
B TR2/3/3A oil pump drive shaft removal challenge on TR3 Triumph 14
Patrick67BJ8 Oil Pump Recommendation[s] for BJ8 Austin Healey 12
M Healey 100-4 Oil Pump Condition Check Austin Healey 3
BillW103 Oil Pump Spridgets 24
TulsaFred Oil pump priming access Spridgets 8
richberman Anyone rebuild oil pump gears Austin Healey 1
