1275 oil pump, camshaft adapter
Rut
Just saw that BPNW now has an adapter for the A+ pump to 1275 cam adapter...slot to star?
Rut
dklawson
Are you talking about CHM108MOD? If so, that's a good price. Literally 1/2 what Mini Mania sells it for.
59diamond
I recently had to have my oil pump replaced on my 1275. It turned out that what I had was an oil pump for a 948. The slot for a 948 is shorter than for a 1275 and eventually wore down and didn't make contact anymore. It was replaced by a oil pump from Mini Mania and all is good now.
You can see a discussion of it in MG Experience under posts started by Bill M. Luckily it was caught in time and no damage was done.
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
R 1275 leak @ oil pump Spridgets 5
D MG Midget 1275 rear oil seal. Spridgets 0
S 1275 oil pan removal Spridgets 30
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
Jim_Gruber Looking for Oil Tube for a 1275 Spridgets 12
F MG Midget 1275 oil leak Spridgets 7
T 1275 transmission oil leak Spridgets 2
Rut 1275 oil change Spridgets 6
I 1275 spin on oil filter unit and pipe for sale? Spridgets 8
theleisure 1098 & 1275 Oil Pans-- Same or Different? Spridgets 4
C 1275 ran without oil for 5 miles... Spridgets 30
abarth69 1275 PCV valve and oil leak Spridgets 7
EVSpriteGuy Oil for 1275 ribbed case tranny??? Spridgets 1
O 1275 oil pressure--NOT! Spridgets 5
dingleberry3343 74 midget 1275 oil galley plug Spridgets 6
Bruce_B Oil Galley plugs and 1275 rebuild question Spridgets 2
B Oil cooler engine adapters for a 1275 Spridgets 10
P 1275 Oil Filter?? Spridgets 22
Kurtis 1275 Oil Filter Change on a Bugeye... Spridgets 10
S MG Midget 1275 Gearbox Oil - Help Needed MG 3
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
