Morris
I have been having low oil pressure problems lately. If I put "shims" on the return spring, my oil pressure is roughly 60 at cruise and 15 at idle. Without shims it is 45 at cruise and 10 at idle. Today, after a long highway drive, my idle pressure dropped to nothing. I would like to address this problem quickly as I currently rely on my Midget for my daily driver. But also, I don not have an unlimited budget or amount of time to work on the car. What would you do?
A) Install an oil cooler. My oil pressure is always worse after a long (20-30 minute) highway drive. And my oil, though fairly new, is dark for it's age.
B) Replace the oil pump. As my cruise pressure seems to be alright, the pump seems like an unlikely culprit.
C) Replace my cam. The 1500 has no cam bearings. When I rebuilt my engine, the journals where questionable. I wanted to replace my cam with one from an early Spitfire. The early spit cam does use cam bearings and both the bearings and cam fit nicely in the 1500. I have since found a source for an early spit cam. Someone had suggested that the symptoms I am experiencing are due to too much bearing clearance.
D) Replace the crank bearings. When I had the engine rebuilt a year ago, they turned the crank. I checked the clearances before assembly. They were on the high side of spec.
