Off the shelf oil filter
Rhodyspit75
Does anyone know of an oilfilter for a Spitfire 1500 that I can pick up at the local auto supply. When I rebuilt my motor I ordered one from Spitbits. It was a Fram ph2869. I saved the box thinking I could just pick the next one up locally. Wrong!
At my third store yesterday, the guy at Car Quest cross referenced it to a Wix number that had the wrong thread.
The filter I took off was a Crossland 595 with the notation"for future replacement leave threaded adapter in engine and use filter 670". So I am thinking I have the 5/8 adapter.
Any help would be appreciated.
HerronScott
All the ones that I see at the Autozone/Advance Auto websites mention they work when converted to 3/4" adapter and there are plenty to choose from. I'd consider getting a 3/4" adapter.
Scott
HerronScott
I found another reference to the 5/8" to 3/4" adapter which indicates that the Wix 51312 oil filter comes with that adapter. You can find that oil filter at RockAuto or even Amazon (where ever you can find the cheapest shipping).
Wix oil filter with adapter
I seem to remember buying oil filters for my wife's Spitfire many years ago which came with the adapter as well. It was probably more common then to include it than now.
Scott
jfarris TR2/3/3A Off the shelf oil filter Triumph 9
K TR2/3/3A Old school battery shut off switch....... Triumph 3
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
B TR4/4A Headlights Blink Off Triumph 15
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Editor_Reid TR2/3/3A Original Knock-Off Hammer Triumph 14
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
Editor_Reid Knock-Off Hammer Austin Healey 8
kodpkd Signing Off Austin Healey 8
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
T Knock-Off Spinners Austin Healey 43
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
G Engine Will Not Turn Off Austin Healey 10
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
T TR4/4A Fenders off the car for paint? Triumph 8
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
R Turn Signal Knob goes off center Austin Healey 9
J BJ8 flywheel take some pounds off Austin Healey 17
A Setting Camber Really Off Austin Healey 13
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
JPSmit So I guess I don't need to lay off the churros after all Spridgets 4
S TR2/3/3A Frame off vs. body on restoration Triumph 21
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
B TR4/4A Can't get rear extension off. Help! Triumph 24
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
JPSmit Off to bed for the winter Spridgets 10
TomMull Knock Off Tool Restoration & Tools 6
S MGB When your breaks off. who ya gonna call......? MG 2
L Tight spot on steering box is way off Austin Healey 18
R TR4/4A Speedometer off 10mph Triumph 6
Boink MGB MGB-GT off-roading? MG 4
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
J Gas pump auto shut off question Austin Healey 2
Got_All_4 TR6 How does this steering lock come off Triumph 9
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
Got_All_4 TR6 Rear Panel Reflector off a parts car? Triumph 8
D TR2/3/3A off topic , but can you help with a quotation Triumph 5
T TR4/4A Heater control valve - cant completely turn off Triumph 3
JPSmit Off to British Car Day Spridgets 8
D cut-off switch Austin Healey 20
D TR2/3/3A curious tachometer take-off Triumph 5
Joe Schlosser Transmission Tailshaft housing off center Spridgets 3
Jim_Gruber New Shoes, New Shoes Bugsy got to show off his new shoes today. Spridgets 6
A turn signal knocked off center Austin Healey 14
J For Sale 1980 MGB - frame off restoration 1,700 kms ago MG Classifieds 0
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
CJD TR2/3/3A Knock Off Differences Triumph 13
S TR2/3/3A bezels off the switches Triumph 5
