Carbon seals were used extensively in the '30s & '40s. By the '50s, most were gone. By looking in the Service Instruction Manual on the TRactor pump, it looks like they use spring loaded phenolic assembly on the impeller side that seats against the cast iron of the pump body. Should be no need to run that dry to get it to seat.
<span style="color: #FF0000"><span style="font-weight: bold"><span style="font-style: italic">If carbon seals were used 50 years ago, why wouldn't Moss require seals using modern improved materials? Isn't this a giant step backwards, or does the small supplier use tools and materials that are 50 years old and not up to spec.?</span>
</span></span>
BTW, I have rebuilt my share of carbon seal pumps, and as long as you machined the mating surface true, they wouldn't leak. All you had to do is vacuum test the darn thing to know if all was well.
<span style="color: #009900"><span style="font-weight: bold"><span style="font-style: italic">I have received parts from major suppliers that could not have been tested. Or they were tested and shipped even though they failed. This is not an exaggeration. What makes you think the Indian supplier would do a vacuum test? I doubt it.</span></span></span>
There's NO EXCUSE for a leaking pump going into the box. I don't care what type of seal it has.
<span style="font-weight: bold"><span style="font-style: italic"><span style="color: #FF0000">I agree completely AND as I have stated before, on the forum, one must also take into consideration the "in and out" costs, that is, the labor. Something like a water pump needs to be reliable enough to minimize a repeat of the the installation.</span></span></span>
Edit: Unless we're talking a pump that has packing in it...those are designed to weep a bit to keep the shaft lubricated. But those type of pumps always had a catch basin for the drips. The water would then evaporate out of it. If it filled too quickly, then the packing is not tight enough. This is the type of water pump that can benefit from water pump lube.
And one more thing, if it is beneficial to spin the pump up dry before use, why doesn't the manufacturer just do it. It certainly would be easy enough. Then they can vacuum test it again. This is all just a cop out and I ain't buying any of it.
