The BJ8 finally showed up in New York, courtesy of Horseless Carriage (who did a fantastic job and picked up the slack after InterCity dropped the ball and cancelled a pickup on less than 24 hours notice and after charging my card). Thanks again to all in helping me sort out the best way to get the car halfway across the US.
The car runs well, but clearly hasn’t been fussed over and I am in the process of finding a good mechanic on Long Island who properly understands the British classics to go over things and make sure all is generally in good running order.
She seems largely original to me- clearly a recent respray, as she came from the factory with a white exterior and is now Healey Blue with white coves, but the black interior seems original (save the carpet), as does the distributor, original oil filter, and all the other under the hood bits.
As I will be handing the engine compartment over to a mechanic, I’ve focused on the interior for now- many loose screws, dials twisted in the dash, etc. I also performed the dreaded strip down to completely loosen the dash and remove the RPM gauge in order to get behind the choke cable and (hopefully) permanently seat the lock nut so the choke does not come halfway out the dash each and every time it is pulled. Now on to the areas where I’m lacking proper insight:
I had a blown bulb in the highbeams warning light and pulled the tube from the back of the speedo. In reseating it, the light was strangely not coming through to the blue lens, and after pulling the speedo, I noticed a white rubber piece buried in speedo that was blocking the light- can I pull this off with impunity or does it serve a vital function? I don’t want to disassemble the speedo and it seems this white gasket was bent over in time and is no longer doing its job. Seems I’d best just pull it, but maybe that’s a bad idea. While I had the gauges out, I also replaced the o-rings between the bezel and the dash which were cracked.
Trafficator is next. It functions to activate the lights but does not hold either to the left or right. I’m hoping someone installed the plates upside down, but once the new moto-lita arrives I will take it apart and find out.
I also spent a good deal of time tracing a problem where the car had no high beams. Low beams were fine. I had power coming off the dash switch to the blue wire, and pulling the plugs and jumping the wire connectors connectors at the floor dip switch did not activate the highbeams, so it is not a dip switch issue. I was ready to start crawling through the hood tracing the wires when I decided to tackle the choke issue, above. After completely reassembling the dash the high beams now work, which leads me to believe I have a short somewhere under the dash, yet I didn’t touch a blue wire (at least I don’t think I did). I’m not confident that the highbeams will stay “fixed” so if anybody has any ideas on where I should look for the problem, I’d love to hear it.
Finally, the seat pans are nearly completely rusted out and hopefully I will be able to replace them while reusing the original vinyl, or I will likely leave them to rot, as I have no interest in reupholstering the interior. Don’t love all the orange fleck on the nice black carpet, however. My question is right now the driver’s seat sits very loosely in the frame, and slides out to the front nearly every time I enter the car- is there some retaining system I can replace, or are the seat bottoms supposed to simply rest in the frames?
I’m sure that’s quite enough for now- appreciate any and all advices.
