MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted?
Vardaman
I put a new 12v battery in place of the original dual 6 volts, and have been troubleshooting the electrical system. All seems to be going well, but then I read someplace that these cars were originally positive ground. If it has an alternator, that pretty much proves that either someone converted it, or somebody REALLY didn't know what they were doing. What else might be a sign that it has been converted? What might they have missed?
BobHaskell
Which way were the 6 volt batteries installed? Negative or positive connected to the chassis?
mezy
Sadly, I didn't think to look. I just noted which cable was which.
If you noted which cable was which,
Which one is connected to ground.
I don't know that any positive earth alternators were ever made, they came along, way after manufacturers went negative earth.
PAUL161
I think I'm correct on this as I've had both, 1978 MGBs on were Negative ground, before that they were Positive ground systems.
PAUL161
My 70 and 72 were both positive grounds. ?? My 78 was negative ground. Again, ??
Joe Reed
All MKI cars ('62-'67 model years) were equipped with a dynamo (generator) and were positive ground.
All later MGBs ('68-'80) were equipped with an alternator and were negative ground.
V
Vardaman
Mine is a '66, so it was originally positive ground with a generator. It has had an alternator retrofitted (it's kind of a kluge, but at least it's not Lucas!!) So my question is, if someone added an alternator to a car that was originally positive ground, would it necessarily have been converted to negative ground?
mezy
Yes
It would have had to be converted to neg earth for an alternator
Platinum
Alternator fitted? Decidedly the car was changed to negative ground. Converted our '64 to negative earth back in '05 when doing the rebuild. Put an alternator in a couple years ago, a Lucas unit. Replaced the external regulator with the faux box sold by one of the regular suppliers, it reroutes the wiring internally, just to approximate original appearance. Also swapped out the cover with the Lucas one just for S&G. Looks like the "original." Also put the "IMPORTANT: This vehicle is negative earth" decal on the under-hood panel.
Mickey Richaud
NutmegCT
Vardaman - " It has had an alternator retrofitted (it's kind of a kluge, but at least it's not Lucas!!)"
Following on Mickey's reference to the positive ground alternator, what make/model alternator is on the car now? And could you give some details on the "kluge"?
Tom M.
V
Vardaman
Tom M.
I really hadn't looked, but had assumed that it was something more modern. In fact, it IS a Lucas with the internal regulator. The "kluge" is that it uses the original alternator mounting bracket with a long bolt and a thin sleeve forming the rear brace.
Platinum
I believe we got this "extended" bracket through Moss, but don't remember for certain.
mctriumph General TR They are never DONE!! Triumph 5
mctriumph General TR NEVER start a car with stale gas Triumph 0
AngliaGT MGB-GT I Never Thought of an MG as a "Cookie Cutter" Car 'til Now MG 3
69MGC T-Series Never thought I'd switch MG 5
R General TR Emergency hot wire - because you never know whats next Triumph 2
JPSmit Ford Taunus - never seen on in the flash before Spotted 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
F TR2/3/3A RULE#1 Never throw anything away Triumph 3
Gliderman8 General MG The car that never was MG 6
V TR4/4A Learned to drive in my father's 1958 TR3 58 years ago, never got over it Triumph 3
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
D never throw old parts away.... Austin Healey 7
doc50 TR2/3/3A Never seen a TR3 with this feature. Triumph 2
CZ_Dave MGB Ya Just Never Know What Cha Find MG 5
drambuie You never looked so good! Austin Healey 9
mrsprite Old Spridgets never die... Spridgets 6
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
Keoke SEE it is never too late Austin Healey 3
JPSmit Bring a Trailer - I never even knew this existed Spridgets 4
DNK Never Seen One of These Before Other British Cars 3
Sherlock Betcha never heard of this one... Other Cars 6
hilsideser Never seen one of these before... Spotted 5
AH67 facet fuel pump never stops ticking. Austin Healey 6
Jim_Gruber Never throw anything away!! Spridgets 7
DNK Never saw that... Triumph 0
Mickey Richaud Never Seen One of These Sunbeam (Rootes) 0
bighealeysource Never been in a Concours - what do I need to do ? Austin Healey 22
G Never give up hope ! ! Triumph 2
HealeyRick Sunday Will Never be the Same Austin Healey 0
JPSmit Never seen one before Other British Cars 8
drooartz Never been so happy to have a speedo die MG 0
MCNX_BFF Triumphest 2010 pix --Better late than never? Triumph 4
PATR8 I know why I never have time to fix my stuff Triumph 6
JPSmit I've never seen one of these for real Spridgets 5
drooartz Why you never throw anything away Spridgets 16
T Never quite know what you are going to find... Triumph 14
livinginthepast BE horn never worked. Now it won't shut up Spridgets 12
G Never buy a tube of grease AGAIN!!! [well, almost] Spridgets 7
Hap Waldrop Beer run pics, better late than never :] Spridgets 6
Jer you never know... I just bought a Bug Eye ! Spridgets 21
Jer never know who you will meet at a car show... Spridgets 4
DNK It never ends. Triumph 12
glemon Never Assume [Ignition Timing] MG 1
M TR2/3/3A NEW MEMBER INTRODUCTION BETTER LATE THAN NEVER TR3 Triumph 19
Jim_Gruber Never overlook the simple stuff Spridgets 1
JPSmit It never rains, it pours Other British Cars 12
T Never seen one of these.... MG 11
C Better LATE than NEVER! Triumph 18
PHerder Never know what you will find in the trans tunnel! Spridgets 14
S Here's a TR variant most have probably never seen Triumph 7
