Mounting Fender Mirrors
amphibispridget
I'm considering putting fender mirrors on my 72 Midget. Are there any tips for mounting them, or is just a question of drilling holes and bolting them on? I'd be placing them above the center line of the wheels, and I know they're pretty much useless. But I think they're really cool. Thanks for the help with my other posts.
bobmga62
When I bought my MGA, it had the Lucas mirrors on the front of the fenders as you describe.. kind of like the originals..
They are an absolute PAIN!!!
As soon as I do the body over, I want to fill in the holes and re mount the mirrors..
They go out of whack all the time... Between brushing up against the car, accidently knocking them, or even pulling my dust cover over the car they go out of whack!!!
As much as I tighten, they still are not firm enough to hold their location..
And when it comes time to actually work on your engine, they are always in the way.. they are just at the point you always seem to want to lean over the engine... I even scartched the paint with the mirror hitting the paint..
I know thy look "cool" and follow suit to original repros... but unless your using a really "solid state" mirror, I would stay away from it!
Enjoy
R
Steve_S
I have fender mirrors and I love them. You have to get convex mirrors because the flat ones have too narrow a field of view to be so far away. The practical advantage is that you have no blind spot once they are adjusted properly. There are disadvantages like having to get out of the car every time you want to adjust them. Or recruit an offspring as my father did to me many times with this very car!
The only tricky part of mounting the mirrors is getting them even. Forget the old saying of "Measure twice, cut once". Measure three times. If they are uneven it will bother you forever!
Bob, I've never had a problem with my mirrors slipping. I have the rubber pad under each mount and I tighten the mirror disc screws fairly snug. I can still force them to move which is good in case something hits them (won't break the mirror) but they hold their own position just fine. Maybe your backing plate screws are not tightening properly?
Here is a photo of the mirrors on my '65 B roadster:
bobmga62
Yep... got the exact same things in the same postion on the A...The mounting to the fender is fine...its the socket joint that seems never to be tight enough.. and like you said, your jumping in and out of the car three times to adjust the mrrors, or ( per usual) before the wife gets in the car.. its "Honey, can you adjust the mirrors.. up.. no down.. no left.. up again.. right...not so much!"
My first A I put a set of racing mirrors on, (the teardrops)... they look ridiculous way up front, but I placed them just far enough up the fender, to still see them out of the windshield..almost is line with the post, so they were in line aprox. with the vents grills on the MGA... they worked great!!
P,S. How do you post your picture,, I have not figured that out yet.. your B lookes Absolutely great!!!!!
Bob... from 100 yards shy of the absolute opposite coast...
Steve_S
Thanks for the compliment. It's all in the lighting. Doesn't look that nice in person. /ubbthreads/images/graemlins/smile.gif
To post a picture you need to first upload it to your (or someone's) web space. Then get the URL of the image (i.e. https://www.mywebspace.com/myphoto.jpg )
Next, make your post here on the forum and wherever you want the image to appear, insert an image tag before and after the URL. Example (leave out the spaces):
[ img ] https://www.mywebspace.com/myphoto.jpg [ / img ]
Note the '/' in the end tag. That tells the forum software where the end of the image link is.
You can also make a text link to the image by using the URL tag. Example (again leave out the spaces):
[ url = https://www.mywebspace.com/myphoto.jpg ] Link to photo [ / url ]
It will appear like this:
Link to photo
For more UBB Codes, go to the reply screen (not the quick reply box) and check out the "Instant UBB Code" box.
Rut TR4/4A Fender beading mounting tabs Triumph 3
mountainman TR2/3/3A TR3 Rear Fender Mounting? Triumph 4
Lin Mounting the RH front fender [wing] Austin Healey 0
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
SherpaPilot TR6 Engine Mounting Question Triumph 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T SU Fuel Pump Mounting Austin Healey 5
Darwin Spitfire Motor mounting help Triumph 1
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
S TR2/3/3A Body Mounting Bolts. Triumph 14
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
D BJ7 Hood frame mounting plate Austin Healey 7
Editor_Reid H6 Carb Mounting Austin Healey 4
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
C Front sway bar mounting? Austin Healey 10
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
Gliderman8 TR6 Inertia switch mounting location Triumph 4
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
F TR2/3/3A Mounting Slave Cylinder Triumph 41
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
RickPA Mounting number plate on front bumper Austin Healey 4
R Mounting rear shroud rain gutter Austin Healey 14
R Mounting wipers Austin Healey 8
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
G Steering Column Mounting Austin Healey 1
red57 1960 BT7 top mounting brackets Austin Healey 4
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
B TR6 Gearbox mounting crossmember Triumph 10
F TR2/3/3A radio mounting plate Triumph 4
Branson box spridget grill mounting tabs / ears / brackets Spridgets 3
jfarris For Sale New 8-Blade Yellow Fan and Mounting Kit Triumph Classifieds 0
catfood BN1 Exhaust mounting Austin Healey 8
