More progress today
jlaird
Tis a bit cooler.
Droped the tank to see why my fuel guage did not always work.
DUH, conection to sender was loose, put it back with a lock washer. Works a charm now.
Dumb things, guess I screwed up on that. But bet I never have to do it again.
Now off to get a tank of fuel, road trip.
GB1
way to go!!!
/bcforum/images/%%GRAEMLIN_URL%%/driving.gif
jlaird
jlaird
Guage works as it should. I screwed up when installing the wire.
Now to pull the engine, guess that will start Fri. need to replace oil pump, and clean up tranny second gear, think the indent on the shifting rod at the netural position side has a burr. No clue as to how I am going to get one of those oil pumps in. It did not want to fit under the cover when I tried last, I guess I need to see or figure what is holding it out and do a bit of cutting or shaveing on the pump case. Who would have thought. <span style="color: #FF6666">Anyone else had this problem?</span>
Also thinking real hard about the pressure plate and the clutch disk. They sure looked good when I put em in there but they are not new.
Oh well we will see, I can get Tony to overnite em if necessary. Well second or third day in any case.
kcbugeye1275
If your pressure plate was new, its probabbly good. No more than you have driven it, the clutch disc is hardly broken in.
tony barnhill
Great Pumpkin - R.I.P
As I recall, Jack, you reused your old clutch/pressure plate, didn't you? If you do the clutch don't forget a throwout bearing also.
jlaird
jlaird
Clutch disk and pressure plate are not new, throwout bearing is of course.
Bayless More Prefect Progress Other British Cars 2
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
ecurie_ecosse More progress. MG 6
drooartz Bit more progress tonight, nearly there Spridgets 21
W A bit more progress Spridgets 7
Tabcon A bit more restoration progress with pics. Triumph 24
T One more wiring question [and some progress] Triumph 5
healeyboz a bit more progress for me too Spridgets 5
T more progress and a question..... Spridgets 1
tomshobby finally, more progress Triumph 8
tomshobby more progress Triumph 8
G more progress Triumph 4
mgb4tim More progress - WOW, I finally worked on my car! MG 25
jlaird More progress Spridgets 0
jlaird More Progress Spridgets 0
jaybird Not tired any more --AKA progress! MG 32
jlaird More progress Spridgets 1
Basil More brake progress Jaguar 3
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
