One more wiring question [and some progress]
tdskip
So I got the dashlights, front running lights and driver side headlight working (hoo whoo). Passenger side is likely burned out so I'll deal with that in the normal course of business.
There is a wiring assembly hanging loose in the drivers side footwell and I'm not quite sure what to do with it.
The alignment of this image is wrong - mentally turn it 90 degrees to the right so it is hanging down.
DNK
That is the connection of the front and the rear wiring harnesses.With all the paint on it I can't remember what the small one is for. Maybe the seat wires?Do they match up with the seat buzzer?
G
Remember, everything is color coded. Just follow your wiring diagram to see what that plug is. My 73 had a seat belt interlock. Just cut it out.
mrv8q
TD, as best as I recall, you should have a matching 8 pin plug to the one you show.... I only buttoned up the cover just last week. That side of the car is inaccessible to me right now, otherwise I'd take it apart, and snap you a pic. I only remember because there are two long strips of tape holding those plugs against the inboard side of the footwell, covered w/ the interior panel. I unplugged them and treated them with contact cleaner, and a little dielectric grease...
Perhaps someone else will chime in....
John_Mc
One of those wires on the 3-wire plug looks to be blue/black (or black/blue). On the '74 wiring diagram it looks like that goes to the LH seat sensor switch. The other wire is probably black/brown and goes to the LH seat belt switch. The third wire I'm guessing under that paint would be green/light green and would go to the neutral safety switch (whatever that is). I'm just going off the wiring diagram. I'm assuming the larger plug goes to the rear lights.
T
tdskip
Thanks guys - sure enough that was the front / rear connection point. I now have power to the rear of the car. Once the front to rear conneciton was made it took a couple of minutes to figure out that there was a bad ground but once that was fixed the running lights started working.
No turn signal or flashers yet, and the brake lights are still out, but at least I have then connected.
I really appreciate the help!
K TR2/3/3A More wiring confusion re: diagram? Triumph 5
K TR2/3/3A More wiring questions? Triumph 5
tmc More wiring questions Triumph 21
bighealeysource More news on burned out wiring harness - HELP !!!! Austin Healey 4
jvandyke and still more wiring q's-blinkers! Spridgets 9
Bruce_B More questions on wiring 59 BE Spridgets 10
Bruce_B More wiring questions on my 59 BE Spridgets 3
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
