modern radio
rjc157
trying to install a modern radio seems simple enough but just can't get it to work. i have a neg ground car any thoughts its a pioneer deh-x3500ui
GregW
Platinum
I've installed a few radios in my time, only one in a Healey. There should be 3 +power leads for the radio. One for power (main), one for memory backup, one for illumination (works with the light switch in the car. Usually, I've seen power as a red wire, yellow and orange for the other two functions. What kind of radio do you have and where are you at specifically with it?
rjc157
rjc157
there is a yellow wire that has to be attached to constant power where should i attach it to which side of the fuse box
vette
If your car has original wiring, you have two fuses. The top fuse is energized from the ignition switch when the switch is on. The bottom fuse is hot all the time. On the top fuse, the side with the white wire is power coming into the fuse and the side with the green wires is the circuits being protected by that fuse. On the bottom fuse, side with the brown wire is the power coming into that fuse and the side with the purple or brown/green wire (depending on the year of the car) is the circuit that is protected by that fuse. The original plan from the factory for an optional radio was to supply the radio from the supply side of the bottom fuse, and install an inline fuse holder to protect the radio.
GregW
Platinum
It looks like you have a BJ8? Behind the center console is a brown wire that was for the original radio. You could fuse the yellow wire and attach it there.
Ah, found an old photo of mine in another thread.
attachment.php
M Fitting a modern radio Austin Healey 9
rjc157 Modern Radio Austin Healey 12
drooartz Removing modern radio MG 5
B Modern radio for BJ8s' Austin Healey 0
DrEntropy Some crabbing about 'modern' cars Other Cars 11
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
M TR5/TR250 Compatible Modern Tire Size Triumph 5
glemon Modern Cars [and some perspective] Other Cars 9
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
Tremelune Wanted Austin Healey 3000 with a modern engine Austin Healey Classifieds 0
M Modern Paint Code Needed for Honolulu Blue Restoration & Tools 1
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
71TR6 TR2/3/3A Modern paint code for 1959 Triumph #19 Pearl White Triumph 20
billspohn Modern Classics-to-be? Other Cars 33
T Modern Oils for Our Flat Tappet Engines Austin Healey 26
T Modern Oils for Our Flat Tappet Engines Spridgets 7
M Modern Parts & Service Spridgets 21
GTP1960 TR2/3/3A Modern blade fuse box ? Triumph 20
Healey Nut Modern accoutrements Austin Healey 23
glemon Modern Morgan? Other Cars 3
C BMW or other Modern engine-What would you use? Austin Healey 33
Sarastro T-Series Modern Electrics for a TD MG 9
M_Pied_Lourd TR2/3/3A Modern Paint Reference Numbers Spa White Triumph 7
5 Modern [Burlen] SU fuel pumps Austin Healey 7
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
Bradhowesable TR2/3/3A Modern audio in a Tr3A? Triumph 13
aeronca65t "Modern" classic British Motorbikes 4
K Modern Epoxy instead of Welding? Triumph 13
davidk What size modern tire will fit in spare tire well? Triumph 7
K TR2/3/3A Modern Fuse Box on a Tr3? Triumph 7
cbrvfr Running modern accessories with positive ground? Austin Healey 4
newmexTR3 TR2/3/3A TR3 & Modern Art converge Triumph 5
JodyFKerr MGB Adding "modern" A/C to an MGB MG 10
JodyFKerr TR6 Adding "modern" A/C to a TR6 Triumph 12
dougie "Modern" Healey Commercial Austin Healey 3
JohnnyMead Modern Fuel Shut-off for Our TRs? Triumph 12
bighealeysource Modern color code for MG red MG 3
F Old Cars, Modern Radios Triumph 15
jhorton3 Modern Radios Spridgets 10
prb51 Modern Starters on Tr's Triumph 10
S Modern day Spridget? Spridgets 8
MTribe modern paint code for Signal Red? Triumph 5
A Old English white modern equivilent? Austin Healey 12
John_Mc Modern marvels Triumph 2
R6MGS *modern* cars.....rant Other Cars 21
7 How often do you change... [on a modern car] Restoration & Tools 8
MadRiver Modern or rebuilt alternator? Triumph 14
Thor Modern temporary spare tire that might fit 1500? Spridgets 0
