Metric or US Standard Threads?
Ohiobugeye
Questions, Questions. On the 1275 Block are the threads for the oil pressure gauge attachment and the temp gauge hole Metric or US Standard? I'm using after market gauges and the threads are US Standard.Both seem to thread in easily, perhaps to easily. Also I'm using a standard Bugeye radiator and have the option of using the block or the radiator to connect the heat gauge bulb to, any suggestions on where to install it?
Thanks, Don
smaceng
I do not believe that the 1275 engines had any metric threads. Exactly what those threads are, I do not know. A bunch of straight British pipe threads are used on our cars.
Scott in CA
Install the temp gauge bulb into the head.
The threads on the oil are probably BSPP. But I'm guessing.
drooartz
Does the Bugeye style temp gauge fit into the boss in the head? I've got that decision to make soon as well.
regularman
Thanks, Don
One thing I found when I changed the bulb and capillary tube on the midget was that the newer aftermarket bulb was too long and went in and hit inside before the fitting got tight and the seal was made. What I found was that by putting a ferrel off of a brass 3/8 tubbing on the bulb it took up the slack and kept the bulb from going in too far and allowed the seal to work. The ferrel made the perfect spacer. Don't know if this helps but just thought I would throw it out there.
Ohiobugeye
Ohiobugeye
Thanks to all for the information, always pays to double check. Thanks Again, Don
cdsmith
Yes, but I believe you need an adapter... If I remember correctly the bulb would bottom out with out it. At least that's what I remember when I switched mine from the radiator to the head.
cd
smaceng
Just to teach the ignorant, why do you want the temp sensor in the head rather than the radiator for a BE 1275? I am using a high capacity pump, late model yellow platic fan and the BE down flow radiator.
Scott in CA
Are you interested in the head temperature of the radiator temperature? There is always a difference (esp if the thermostat sticks shut)
nomad
Like to make a point here. Except for the unlikely event of a stuck thermostat how much difference is a few degrees on a not necessarily accurate temp guage really going to make? You need to know your rad caps pressure and what that will do to your boiling point anyway to determine exactly where its going to boil.
Also like to point out that the cappillary tube to the bulb will work harden over time.
For that reason I like to keep it away from any unnecessary vibration.
I think the rad is a fine place for the bulb.
KA
Ohiobugeye
Ohiobugeye
Being that I am using a after market temp gauge and capillary unit I wasn't sure if the bulb would reach to the radiator. As it turned out the capillary reaches both locations, the head and the radiator. I will probably go with the radiator. Do the 1275 Spridgets have the bulb in the head or the radiator?
1275's have the bulb in the head.
What about a water pump/belt failure? The head temperature will show up sooner than the radiator.
I'm sure either is fine, but I use the bung in the radiator to switch my electric fan on/off.
jlaird
This is one of those either or solutions. It really makes no difference at all.
Chances are that if you overheat you will not see it till it is hot at the radiator in any case. How much time do you spend watching the little needle?
I check my instruments quite frequently, but that comes from years of driving unreliable cars. :wink:
cdsmith
I switched to head location just so I knew what temp the engine was actually running at... As an added benefit if I need to pull the radiator - it's one less thing to remove.
cd
bugimike
I agree with cd! on both points, though Jack is right, it is an either/or! I have a VW alum. radiator, so the head was easier!
cd
He said a mouthfull there, think about it, you want to know what the temp is at the head, the hottest point on the system, not the radiator, the cooliest point on the system
jlaird
For raceing I would agree with you Hap, no question.
Not sure I think it is of any great importance for us street guys. After all we don't check the water temp and oil pressure at the end of each lap or more often.
Platinum
I have one eye on that gauge set CONSTANTLY, Jack!! :jester:
...and drive with fingers crossed an' a rabbits foot in me pocket. :wink:
M Thak you and Metric or standard.... ? Austin Healey 5
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
NutmegCT metric washers Restoration & Tools 5
B T-Series MG TD metric tire size MG 5
T kelly metric tires Triumph 7
Z Converting Power/Torque to Metric Units Austin Healey 1
T Who woulda thunk...there's Metric on my car! Triumph 26
B Midget Metric Brake Lines? Spridgets 13
1976Midget English Metric System Spridgets 19
B British, metric, & American thread identification Restoration & Tools 1
S Wanted 1949 standard vanguard Other British Classifieds 0
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
HalLucy Standard Vanguard Sportsman engine and the TR3 Other British Cars 7
M TR2/3/3A Standard Engine Trust Washer Thickness Triumph 18
S General Tech Standard for the Girling Bubble Flare Triumph 15
T Wanted Workshop manual for Triumph 10 [Standard 10] Triumph Classifieds 4
Mickey Richaud General TR Standard 10 Pickup! Triumph 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
NutmegCT 1951 Standard Vanguard Other British Cars 3
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
Tim Tucker TR2/3/3A TR2-4 86mm standard rings Triumph 10
RickB standard size lug studs for 78 Midget? Spridgets 3
C Triumph Standard Flying 8 Triumph 5
B TR4/4A Adding OD to Standard TR4 Gearbox Triumph 18
rlich8 Standard-Triumph Engine Package Diagram Triumph 4
K Early 50's Standard Triumph 1/2 Ton? Triumph 8
wangdango Vandervell bearings for 100M, standard, main Austin Healey 3
bighealeysource Pertronix coil verus standard Lucas coil Austin Healey 3
QuickSilver Technical: Converting From Wire Wheel To Standard MG 6
kurts100 Bugeye Lever Shocks/Standard or Heavy Duty Rebuild Spridgets 14
hilsideser Standard 10 in S.C. on Craig's list for $300 Triumph 20
K TR2/3/3A Standard Continental Touring Kit for TR3 on EbayUK Triumph 0
TR4nut Standard Triumph Gray Colors for Russ.. Triumph 15
K 1950 Standard Vanguard Other British Cars 2
T Neat project - Triumph Standard 10 Triumph 11
Wirewheels Did the BJ7 come with OD standard? Austin Healey 11
germanmichel Standard clearance mainshaft of the transmission ? Austin Healey 3
W TR10 / Standard Axle for Lotus Triumph 10
pakiwi 1275 Cam Specs - Standard Spridgets 1
PeterK standard-triumph hardware catalog Triumph 7
MadRiver TR6 Standard TR6 Tires? Triumph 2
ncbugeye Tyres for standard Bugeye rims Spridgets 1
G Standard Vanguard Paint Code Other British Cars 4
Alan_Myers If I had room, time, $! FS: '47 Standard Flying 14 Triumph 2
Sherlock Standard Herald [India] Other British Cars 5
A MGB How much Torque can a standard MGB gearbox handle? MG 5
bobh A Radical Idea? Or An Old Standard? Triumph 11
gsalt57tr3 1953 Standard Vanguard Phase II Other British Cars 0
gsalt57tr3 Standard Vanguard Triumph 2
gsalt57tr3 Standard Vangard in St. Louis MO Triumph 2
