Max size for BE Tires
Jim_Gruber
Can a set of 205X60X13 Goodrich T/A's work on a BE? 4.5" rims.Minilite Minotaurs.
$550 for 5 ? < 3k miles. Tires about 8 years old, close to max age. Thoughts.
Gerard
I would say you need a 6" rim to mount those. I have that size on my Morris pickup with (6") Cosworth Vega wheels. You might squeak by with 5.5", but I wouldn't try on 4.5". They will be too wide anyway and rub unless you get a big offset wheel or use 1" spacers. In any scenario, the will stick out way past the fenders and would require a flare. Even 185x60 will rub at full lock.
Jim_Gruber
Jim_Gruber
Thanks Gerard. That shoots that thought. Or trash the tires as they are 8 y.o already and go with a smaller width tire.
I saw those tires/rims, but I you can get new rims for a just a little bit more.
Or... wait for the VTO classic eight wheels in 14 inch and mount some 185/60r14 Dunlops. Not cheap but very sticky on the road.
Jim_Gruber
Jim_Gruber
Decisions, Decisions. I need to get Bugsy II home and the $3,200 bill for my Gall Bladder Surgery that arrived today just put a crimp on my ability to spend. Insurance covered all but $3,200 from a $48k bill.
Jim_Gruber
Jim_Gruber
Yep, Gall Bladder surgery + procedure ot remove a Gallstone next day = $48k. Glad I had insurance.
TulsaFred
The doctor's fee from medicare would have been $744 for a laparoscopic cholecystectomy, and that includes all hospital care associated with the surgery and 3 months of follow up visits.
The balance of the $48K would be to the hospital.
Just an FYI.
T what max size tires & wheels fit a tr4,tr4a,tr250? Racing 3
R Max Tire Size for 8" Wheels [how big is too big] Austin Healey 6
B Max Dia for Cylinder Bore for a 3000 Austin Healey 5
Darwin Spitfire Max tire width Triumph 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
S Max RPM Austin Healey 15
R What is max ID of rear drum? Spridgets 7
S TR2/3/3A Mad Max seal Triumph 34
red57 Max safe EGT Racing 9
dondel Oil between MIN and MAX Austin Healey 5
George Zeck Max speed 45mph [or so] ???? Spridgets 10
J TR6 max horsepower from a TR6? Triumph 18
C Max Hoffmann Biography Jaguar 3
ChrisS Max. bore w/ liner Spridgets 3
J Z Max MG 7
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
R Vixen 2500 Lug Nut Size? TVR 5
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Bayless What size battery for my '67 Sprite? Spridgets 5
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
S TR2/3/3A Vacuum Advance Union Size Triumph 1
T Radiator Hose Size Austin Healey 2
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
B Exhaust Pipe Size Austin Healey 26
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
Healey Nut TR6 Headlight size Triumph 58
MadRiver TR6 Emissions Hose/Tubing Size? Triumph 2
JPSmit Not quite an LBC - but the size might be close :) Restoration & Tools 3
B TR4/4A Oil Drain plug size Triumph 14
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
69MGC MGC What size tires will fit nicely MG 2
M TR5/TR250 Compatible Modern Tire Size Triumph 5
J Nut size for BJ8 center console trim piece Austin Healey 8
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
D TR4/4A SU HS6 throttle spindle size Triumph 20
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
Bayless What size fuel line for '67 Sprite? Spridgets 2
S Bugeye Radiator Tank Plug Size? Spridgets 24
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
K Abington Allocation Plate size? Austin Healey 1
R TR4/4A Door mirror base size Triumph 2
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
