That's opening up all kinds of room for firey debate
Before ZMAX was brought to the automotive world the same company that makes it came out with "Avblend", an oil-additive certified for use with certified aircraft engines (which is kind of substantial in that it had to be approved by the FAA). From what I understand AVBLEND and ZMAX are similar products (AVBLEND smells like ether, not sure about ZMAX). Avblend is for aviation use, ZMAX is for automotive use.
I know people who use AVBLEND all the time in their engines (it's very common), and some who wouldn't use it on a bet. There are FBOs that rent and maintain aircraft that swear their engines look like new inside after religously using AVBLEND. They claim their valve/ring problems dropped to nill once they started using the product.
A friend of mine put a new engine on his airplane a couple of years ago and decided to use AVBLEND on every oil change. After 3 years and about 1400 hours later he hasn't had to replace any cylinders on the engine, and it's been absolutely trouble free. Who knows if that is directly contibutable to the AVBLEND of course, but it certainly hasn't ruined the engine.
To be sure aviation oils and automotive oils are markedly different and a lot of the "build up" issues are drastically different between the two. Nevertheless quite a lot of mechanics swear that AVBLEND reduces wear and carbon buildup on valve parts and rings - over and above just regular oil changes at every 25 or 50 hours (it isn't an occasional use item, you replenish the additive every or every-other oil change at a minimum).
I doubt seriously that ZMAX would have any significant negative effects on your engine, but whether it has the same positive effects people claim to have seen with AVBLEND remains to be seen.
[ 02-07-2003: Message edited by: aerog ]</p>
