matching 1275 to bugeye rad ??
Tomchillvet
the water outlet on top of 1275 goes in opposite direction of where bugeye rad inlet goes- is there an outlet that will go rt instead of left or is that a figment of my imagination or is there another trick thanks
Gerard
Because the thermostat studs are oriented slightly different on a 1275 head from all the others, using one from an early head doesn't work out all that well as the angle is still wrong for standard hoses. This is due to the emissions air pump used from early on in the 1275 installations. You need to find the one that was used on non-emission cars sold in the UK. It will be aluminum, not cast iron. If I'm not mistaken, the one for the MGB might be the same as the one you need. I would check Moss UK.
Joe Schlosser
Gerard
So that is what the big Boss is for on a 1275 thermostat housing cover. Seriously I always wondered what that was for. I only started playing with 1275 motors on race engines so I had no idea what the boss is for
AH Spares does not show this boss on their part
Tom
Unfortunately, the one 948 thermostat cover I have in my parts bin is the old flat top type fo which I understand you cannot get a modern thermostat to fit. Moss has an article on it on line.
Moss, lists part number 460-485 for use with a 1275 and a vertical radiator. While not Moss this is what I am using on my BE with 1275 and orig vertical radiator
AH Spares has the same part listed for a 1098 and a 1275 with a vertical flow rad.
Did you find a shifter lever?
T
Tomchillvet
the number for moss 460-485 comes up as a collet- and you believe part number XCHT123 with ah spares would work on the 1275 using BE rad - i did find a shifter and ribcase trans with a ribcase for parts for 100 bucks- 6 hrs from where i live - lucked out there- so now i have 3 ribcases and one shifter lol---thanks for the reply Joe
T
Tomchillvet
i wonder if mgb would be same---maybe someone on here would know-- or if i found one to measure stud distances---cheers gerard
gfholl
I'm using the Moss 948 outlet #460-890 and just a aftermarket hose and thermostat. The angle is a bit off, but it works for me, plus I like how it looks.
Gary
Joe Schlosser
The Moss US# is 460-855. They say that it is for a 1275 with a downflow radiator. I am pretty sure this what I am using on my 1275 although it came from a parts car most likely a 1098.
The AH Spares is probably the same part. The part that Gary is using is more in keeping with the BE look.
Sorry, I do not have a spare outlet (two 1275 for a cross flow though)
Glad you solved your shifter issue. I do have a couple sitting around.
T
Tomchillvet
Thanks for your reply---- i see in vb catalog it shows 3 pieces at bottom of shifter but can only get 2. is the 3rd part hard to get. it shows ring and spring but what is the other part because i don't have any of these parts--thanks
gfholl
The MOSS 948 outlet is designed to take a aftermarket thermostat. The stock ones are what you read about.
Joe Schlosser
Tom
Have a look at the Moss Catalog. It sounds like you are looking for the bits that they call an Anti rattle kit. All the bits under the shift lever.
Surprised that VB does not have the equivalent
A Color Matching Austin CU 50 "Dominican Blue" British Motor Corp 3
F Check for matching nrs Austin Healey MK2 Austin Healey 3
Z For Sale 1955 MG TD Original car, numbers matching, restored to immaculate condition MG Classifieds 10
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
Editor_Reid Matching Funds for Healey Museum Donations Austin Healey 4
TomMull Matching Numbers? Other Cars 5
T TR2/3/3A How important are matching rear shock links? Triumph 9
60TR3A Matching Numbers Question Austin Healey 27
I Matching Green paint on BN1 Austin Healey 1
P SEAT COVERS and MATCHING MATERIAL? Spridgets 4
M TR2/3/3A ???? TR3 Intake manifold port matching???? Triumph 6
Atrus matching speedo to rear end Spridgets 7
Got_All_4 Matching front and rear Anti sway bars Triumph 2
drooartz New tach, need matching speedo... Spridgets 16
Tinkerman TR2/3/3A 60 TR-3A Matching Numbers Triumph 13
beez Moss Performance Header - Port Matching Triumph 8
C TR2/3/3A TR3B With Matching Numbers Triumph 11
bluemiata90 TR2/3/3A tr3 numbers matching Triumph 8
B T-Series matching v.i.n. #'s ? MG 4
P Matching Carnival Red Exterior Paint Sunbeam (Rootes) 2
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
