Moss Performance Header - Port Matching
beez
I recently purchased the Moss Performance Header and was trying to perform a basic port match when I found that two inner ports on both sides are narrower on the header than on the engine. I imagine I can try to drimmel some of the extra metal away to make the port wider but I don't think I will be able to open it all the way. Has anyone else had the same problem with their moss header?
Is this a good header or would I be better off going with something like the Pace Setter header?
Thanks,
Adam
'73 TR6
ALLAN
My Pace Setters have the oposite problem the opening is not tall enough and I will have to grind to port match. I had been running this way and just discovered it while rebuilding my motor. you might try grinding a bevel on the edges if you cant open them up enough, just a beveled grind should help make the transition--kind of a cheated port match
aeronca65t
I have no idea about the Moss header, but the Pacesetter header was a terrible fit on my car. Twisted like a pretzel.
bobh
Beez,
Can you send it back and request a replacement?
What experiences do the rest of the members have with headers? I know Bill had a problem with his. Does anyone have a recommendation for a header that is a good fit?
Simon TR4a
I have had a problem with a header for the TR4a which fitted fine on all cylinders except number one. It was fixable by a lot of port matching but I felt it would have been better to heat and redend the header.
The reason this is so common, I think, is that the cylinder heads are not crossflow, like a V8, so the inlet manifold has to fit between the primary pies of the exhaust header, and it is dfifficult to design a header with a continuous flange holding the primary tubes in the correct positions.
There are headers, at least for 4 cylinder TRs, which have a flange along the bottom, and I expect this would result in a more accurate fit.
I think they are made in the U>K> and sold through Moss as Triumphtune products. I would try to find one designed that way for your car if possible.
Simon.
beez
beez
How about the TRF Group 44 Header? Is this work the money? It looks to be of a very similar design to the Pace Setter (which I have heard bad things about as well). I would like to get the best flow possible and have the ports match correctly.
Thanks,
Adam
73 TR6
swift6
Headers tend to be one of those object that really bear out the "you get what you pay for" mantra. The more expensive they are, the more likely they are to match up correctly. That's the bad news. The good news is that those more expensive headers do actually seem to fit up really well and turn out to be worth the extra money.
K TR2/3/3A Moss Improved performance camshaft 851-051...... Triumph 0
PeterK TR4/4A TR3-4A Improved Performance Cam from Moss Triumph 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
shadowfever Moss Motors MG Midget seat covers Spridgets 6
Celtic 77 MOSS response issues Restoration & Tools 11
BoyRacer Moss Motors Center Consoles Austin Healey 0
T TR2/3/3A Moss uprated water pump Triumph 6
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
vette Latest Moss Motors Magazine Austin Healey 1
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
Basil MGB Moss Motors MGB - Jay Leno's Garage MG 3
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
J For Sale Triumph TR2 TR3 TR3A New Moss Motors Black Karvel Style Carpet Kit Triumph Classifieds 0
3798j General TR Moss Motors acquires Victoria British Triumph 10
J TR6 Moss HS6 SU conversion kit question Triumph 4
steveg TR6 Moss advance kit maximum advance question Triumph 13
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
Upland Moss build-a-paper car contest Spridgets 1
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
JPSmit Stirling Moss - Sebring Sprite Spridgets 3
KVH TR4/4A Door Seals: Moss Part 249-607 Triumph 0
Simmo TR6 Moss Seats Triumph 0
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
E Moss stainless exhaust offering. Austin Healey 28
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
Michael Oritt Moss Motors rear brake "set" Austin Healey 11
K TR2/3/3A Moss Europe has restored the Jabbeke TR2 Triumph 0
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
LarryK Moss Motors buys XKs Unlimited parts house. Jaguar 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
K TR2/3/3A The "compensator bar" on the Handbrake...#53 in Moss diagram Triumph 5
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
L 100/ Moss Heat Shield Austin Healey 2
mt10flyer TR2/3/3A Moss Steering Rack Conversion Triumph 26
Jim_Stevens TR2/3/3A Goodridge SS brakelines from Moss Triumph 3
R Moss permanently lubricated U-Joints Austin Healey 1
S For Sale TR6 New Moss 73-76 Seat Foam Kit Triumph Classifieds 0
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
D TR2/3/3A Moss alternator kit Triumph 8
croz TR2/3/3A Moss Replacement front disc pads Triumph 3
CessnaTPA Moss Bumpers Austin Healey 21
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
