Did a little maintenance that I do occasionally but had apparently put off too long. I removed the fresh air hose at the fan inlet and cleaned out the bug's!! Screen was completely full and there was a couple big hand-full's setting in front of the screen! Vacuumed everything out and ventilation is much improved!!
So if you need a little more air in the foot well I highly recommend checking that spot.
Kurt.
Kurt.
