front end maintenance
aeronca65t
Did some normal, pre-racing maintenance to the front end.
Replaced both A-arms with new ones (plus that lower trunion-threaded pin).
Also all new plastic suspension bushings, new brake rotors and new brake pads.
King pins and tie-rods ends are still OK. Wheel bearings are still good (new from last Fall.....just torqued them back up to 40 ft. lbs)
I did new pistons, rings and rod bearings a few weeks back. Also took about 0.010" off the head to clean it up and installed all new valves. Naturally all oil and filters and other fluids changed too.
Car should now be ready for ~Jefferson 500~ next weekend.
nomad
Curious Nial. Is the original shock just a pivot point now or does it work as well? What do you run for front springs? Whats the auxiliary shock rate?
I'd like to set up the best handling square spridget I could for the street.
Kurt.
aeronca65t
aeronca65t
The lever shock is disabled so it's just an arm.
500 lb front springs.
The compression and jounce rate of the gas shocks is probably similar to the original lever dampers. But the gas units are less prone to fade over longer sessions. I raced this car in enduros for years in club racing, so I needed to be able to rely on the shocks for 3 or 4 hours of racing.
Based on my observation, about half the guys I'm currently racing with in vintage use uprated lever shocks. I may eventually try that but I've been pleased with these for over 10 years. They are Monroe Road Sensor shocks # 5877R
nomad
Thanks Nial, Iv'e always been satisfied with Monroe shocks. I imagine 500# springs might be a little brutal on the street. What sway bar is that?
PeterC
Nial, we're using Redline's synthetic suspension oil now, and find there's no fade or cavitation.
Peter
aeronca65t
aeronca65t
3/4" front bar. I'm not sure what brand....I pulled it off a junk car. No bar in the back (I tried one and hated it).
But I do have a home-brew panhard rod in the back.
Plastic bushing all around, except for the kingpin to lever arm bushing which is stock rubber bushing (it's just my opinion, but I think it's good for that area to have a little "give").
I have about 3 degrees negative camber which I honestly wouldn't be afraid to run on the street in these cars. I used a spacer under the front lever arm mount and also slotted the 3 mounting holes in the lever arm body to allow the change in camber.
Most Spridget racers use stock or even softer rear leaf springs, but over the years, I've come to prefer slightly stiffer rear leafs (I've added two leafs).
This makes the car slightly tail happy, which is more fun. :friendly_wink:
I re-arched the rear leaf springs cold, on a homemade press (to lower the car).
R TR6 TR6 Front end maintenance Triumph 9
G MGB '71 MGB Front End Rebuild MG 2
X Front End Alignment Austin Healey 14
craigshealey3000 Front End Shake Austin Healey 31
B Bent frame rails near BE front end Spridgets 2
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
AUSMHLY 64 front end too high Austin Healey 14
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
vette Effects of Lowering the Front End Austin Healey 21
G Front end Alignment - Total Toe vs. Individual Toe Austin Healey 3
R Front wheel bearing - end float Austin Healey 40
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
K TR2/3/3A Front end woes... Triumph 18
S Wedge tr8 front end Triumph 0
B TR2/3/3A Front end alignment Triumph 23
Jim_Gruber Bugsy IV Front End Rebuild Spridgets 5
mcmillal TR4/4A Front End Vibration Triumph 9
K TR2/3/3A Front end Question.... Triumph 4
M front end alignment Austin Healey 12
T TR4/4A Front end alignment specs for lowered car Triumph 2
Joe Reed MGB Rattle under front end? MG 8
J MGB Project car done; front end clunk noise while braking MG 4
S TR2/3/3A Front end alignment and tire wear Triumph 9
aeronca65t Minor front end work Spridgets 12
RAC68 Calculating Front Hub End-Play Austin Healey 32
bugedd Front end rebuilt help Spridgets 6
BlueMax Front End Completed Spridgets 23
bugedd About to rebuild front end...any tips? Spridgets 5
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
D XJ6 series III front end rattle Jaguar 5
Tr3aguy Front end rebuild questions>? Triumph 6
S Finally got my front end back together Triumph 5
O TR2/3/3A TR3 front End Alignment Triumph 8
RickB Box Spridget fiberglass front end - front mounting Spridgets 5
K TR6 TR6 front end Triumph 2
Burrell22 TR4/4A Tr4 front end help. Triumph 10
B Bugeye front end Spridgets 0
H Should I drop the front end down a little? Austin Healey 25
M Advice on doing a front end rebuild via kit? Spridgets 4
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
S TR2/3/3A tr3 front end alignment Triumph 9
MY66AH Front end question Spridgets 9
regularman Has anyone here put a bugeye front end on a square Spridgets 2
