TR2/3/3A Longer wheel studs?
SASSAMON
karls59tr,
As RonR says, the longer wheel studs are available from TRF. There are two normal lengths for the Triumphs. A standard length for the steel disk wheels and a shortened stud for use with the adapter when used with the wire wheels. If you are looking for longer than standard length studs, good luck.
To find the studs on the TRF website takes a little more work then the Moss or VB website. But I like that TRF will have many parts that are not listed by the others.
To find the parts you will need the Triumph part number. Look the part up in the Spare Parts Catalog. RandallY has scanned the SPC as well as several other manuals and I would rather he provide a link directly.
With the part number go to the TRF website.
Do not use the search box in the upper right of the page.
On the home page look for the blue banner across the top of the page.
Inside this banner is a search tab.
Hover the mouse pointer over this tab and a drop down menu will appear.
One of the choices is Parts Database.
Now we can enter the part number in the left hand search box.
This may seem like a lot of work but I find it works great for me.
Results from the search will show up. If the part is used in a kit or has been updated with a newer number these will show up also.
The 4 different studs are:
114282 Stud Front Disk Wheels 3.98
114281 Stud Front Wire Wheels 3.98
100869 Stud Rear Disk Wheels 3.98
110365 Stud Rear Wire Wheels 3.98
Tybalt
The Roadster Factory
If you are looking for any of the stock length studs for wire (short) or disc (longer by about 7/16" IIRC) wheel fitment, the information is listed above. On the other hand if you are looking for longer than stock length studs, ARP makes some longer studs in a 7/16-20 thread but you will need to determine what size knurl diameter and knurl length would be needed to fit the stock hub flanges to see if the longer ARP studs would work without modifying the hubs. You might consider contacting Richard Good at Good Parts. I know that he has wheel studs in differing lengths, some fit stock hubs, some don't. He could at least put you on the right path if you want longer than any of the stock studs.
https://www.goodparts.com/
K
karls59tr
Bronze
Thanks for the info:encouragement:
K
karls59tr
Bronze
karls59tr,
Thanks for the info.:encouragement:
K TR2/3/3A Source for TR3 wheel studs that are 1" longer? Triumph 8
T longer wheel studs need help finding Triumph 11
zekjet TR6 Longer Front Wheel Studs for a TR6? Triumph 3
steveg Nisonger no longer in service business Austin Healey 12
R J-H no longer needs a push! Other British Cars 6
TomChar General TR LBC's no longer in their prime... Triumph 14
cmacmillan TR6 metering needle - no longer in a relationship with adjustment screw... Triumph 9
J TR2/3/3A Need a longer choke cable, IE: all the way to the pull knob Triumph 1
DrEntropy Can't put it off any longer. MG 10
Ed_K Castrol Syntec 20w-50 no longer available ? Austin Healey 21
K TR4/4A Longer TR4A intake manifold on a 3...... Triumph 5
B I'm no longer safe! Spridgets 23
S This won't last much longer! Jaguar 4
AUSMHLY Longer grease fittings Austin Healey 8
milemarker60 Looking for longer studs? Here's my research Triumph 2
A Its starrting to stay light out a little longer. Spridgets 4
catfood TVR No longer under British ownership... Other British Cars 9
T TR6 Steering Wheel Lock Triumph 2
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
D Removing the steering wheel hub Spridgets 12
Todd78d Wire wheel cleaner Spridgets 1
zoohow wheel spacers Racing 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K 1068 mkIII wire wheel rub Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
K TR6 TR 6 Wheel Studs Triumph 10
AUSMHLY Front Wheel Spin Drag Austin Healey 6
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
Editor_Reid Wrapped Steering Wheel Austin Healey 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
kodpkd Leather Steering Wheel Cover Austin Healey 3
KVH General Tech Wheel Dollies Triumph 5
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
P 100/6 Front Wheel Alignment Austin Healey 10
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering wheel removal. Triumph 4
