LED bulbs and electronic flasher module issues
Johnny
I'm using the rear reflector lamps installed on my BJ7 currently. Will adding LED's work properly, and are they even more brighter?
Rob Glasgow
OK Roger, how'd you get the brake lights to activate when there was no one in the car to step on the pedal???? I'm guessing either a ghost or a very short person...... I had to have my wife help out with the braking shot for my photos......
AUSMHLY
I used the kiss approach.
Leaned one of my jack stands against the brake pedal.
Rob Glasgow
Roger, that's so unlike you. I thought for sure you had fabricated a special device, hidden of course, that would step on the brakes by remote control.
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
gbtr6 TR6 LED light bulbs questions Triumph 20
Rob Glasgow E10 Base LED Dash Bulbs Austin Healey 17
K TR2/3/3A LED dash bulbs again? Triumph 2
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
I TR6 suggestions for brake LED bulbs Triumph 13
5 TR2/3/3A LED bulbs w/turn signals problem Triumph 4
S LED Dash Bulbs Spridgets 10
B LED bulbs as side lights/stop light/flashers Austin Healey 29
Boggsy64 MGB LED dash bulbs MG 3
D TR4/4A Elec Flasher/LED bulbs revisited Triumph 14
CinneaghTR LED Brake Light Bulbs? Triumph 12
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B Positive-Ground LED Light Strip Austin Healey 8
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
J LED lights for PL 700 Restoration & Tools 12
Guido36 LED Headlight Upgrade Austin Healey 1
bighealeysource LED Instrument Lights Austin Healey 12
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
BoyRacer LED Turn Signals Austin Healey 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
P LED Brake Lights Austin Healey 2
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
B TR6 LED Headlights Thouights? Triumph 20
T Decreasing Intensity of LED Lighting Austin Healey 3
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
johnrip Wedge TR7 led light conversion question Triumph 1
ckeithjordan TR2/3/3A LED Flasher Problem Triumph 13
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
Lukens TR2/3/3A Led flasher relay? Triumph 3
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
R TR2/3/3A Positive-ground LED lights Triumph 13
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
Bob_Spidell LED Headlamps Austin Healey 14
Gliderman8 TR6 Correct LED flasher relay Triumph 6
N Charging warning light LED conversion Austin Healey 29
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
J LED Brake / Turn Signal Austin Healey 4
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
Joe Schlosser LED Turn signals Austin Healey 9
Joe Schlosser LED flashers Spridgets 2
Gliderman8 General TR Let there be [LED] light! Triumph 18
D LED shop lights Restoration & Tools 10
GTP1960 TR2/3/3A LED headlight question Triumph 11
Marla TR4/4A Led dash lights Triumph 0
