Leaking 5-speed drain plug
Jim_Gruber
Update: Transfer Idler Gear was installed backwards and was not making full contact between main shaft and lay shaft. Pics to follow in am. I think we’ve found source of whirring noise, gear was only making 1/2 contact connecting to layshaft. Now rear seal leak to fix.
Jim_Gruber
Bugsy Tranny Autopsy 1 100_3743_LI.jpgBugsy Tranny Autopsy 2 100_3744.jpgHere are the pics as promised of Bugsy's Tranny Autopsy. Comments from the Shop Owner on tranny .
So far I have actually discovered the transfer idler gear was on backwards, and was not aligned with the mainshaft and layshaft gears. Assuming this gear had run for its whole life by turning (and seating in) in one direction and was then asked to push the other way, it could certainly explain a noise. It is all I have found so far, but it certainly is an assembly mistake by the last guy. Since it not something that is done wrong with any frequency, it would be hard to say 100% that this would cause a noise.
Here is the only problem I have found so far. You can see the offset of gear teeth outlined in yellow on 3743. On the other photo, 3744, I have turned the gear around and now there is good alignment.
Back to the original problem of a crack around the drain plug. I once repaired on of these by jb welding an adapter/reducer into the drain fitting. Now the oil takes longer to drain but it seems it was a good in situ repair.
Jim_Gruber
Interesting fix Trevor. Driveshaft gets dropped off tomorrow for check on rear seal. Hope this fixes my noise. Drew on the other hand this may be a fix for you.
drooartz
drooartz
Thanks for the tips. My plan now is to swap my spare trans in and see what can be done with my broken one. Worse case is it becomes a donor for internals.
nomad
I spoke too soon, Drew. Sorry, but the rear extension that I will need has the drain plug in it. The transmission I have slated for overhaul in my white Midget has a very worn rear output sleeve. Gears on the layshaft have been chewing some aluminum in this one as well. I imagine it can be shimmed.
Kurt
drooartz
drooartz
No worries, Kurt, thanks for looking. I'll dust off my spare and get it prepped to go in the car.
Nelson New 5-speed leaking oil Spridgets 10
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
S Leaking HD6 Rear Carb Austin Healey 10
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
S TR2/3/3A rear main seal is leaking Triumph 13
R TR2/3/3A Leaking O.D. section of Transmission Triumph 43
E Oil leaking from the Tachometer cable Austin Healey 5
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
D BT7 rear wheel leaking Austin Healey 25
N Leaking Carburettor Austin Healey 11
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
C TR6 Brake servo leaking Triumph 3
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
R soft plug leaking Austin Healey 45
George Zeck Master Cyl Leaking .... Spridgets 5
M TR2/3/3A O/D brass cap leaking Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
rjc157 Leaking steering box Austin Healey 4
B mysterious leaking of SU HD8 Jaguar 9
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
B Rear Engine Side Cover Leaking Austin Healey 9
D Overdrive Leaking Oil Austin Healey 4
KVH TR4/4A Oil Pressure Banjo Nut is Leaking Triumph 6
H TR2/3/3A Leaking Fuel Pump Sediment Bowl Triumph 5
PatGalvin TR2/3/3A Leaking SUs. Advice badly needed Triumph 15
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Michael Oritt Leaking oil pan Racing 8
T TR6 leaking carb TR6 Triumph 17
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
Rob Glasgow Leaking tapered plug on head Austin Healey 8
Scotsman TR2/3/3A leaking front engine plate Triumph 4
bigbadbluetr6 TR6 Carb leaking Triumph 12
M TR2/3/3A Head gasket leaking in two places Triumph 13
