[ QUOTE ]
Hello all,
another thought, In the U.K. again, aviation fuel for piston engines is still leaded, is that the same in America and if so why?
By the way we can still buy leaded petrol here but it's supply is limited and expensive.
Alec
[/ QUOTE ]
Hi Alec,
A partial quote from another web site --
"Currently, aviation gasoline (known as "avgas") for piston-engine aircraft contains four times more lead than was used in leaded automotive gasoline before it was banned from use in new cars in 1973. However, because the lead additive has been the most economical method for achieving 100-octane fuel, leaded avgas has remained the standard for high-performance piston-engine planes.
To avoid damaging the general aviation industry, the U.S. Environmental Protection Agency (EPA) agreed to permit the use of leaded avgas until an economic alternative was developed."
Yes, it is expensive. The USA is looking to alcohol based fuels as a solution, but still has far to go.
Regards,
