lead additive?
RickB
Anyone use the stuff?
I saw a bottle at the auto parts place, said it treats 320 gallons. One ounce per 10 gallons, it's red stuff.
Is this snake oil?
jlaird
Snake oil me thinks. Just run gas from the pump. Valves are cheep and seats last a long time in any case.
Easy enough to pull the head when in future years you need to have it repaired.
fabmandan
It might be "snake oil" like Jack says, but I used it in every fill up in my 1962 Galaxie and I never had a problem. 5 bucks for a bottle that lasts a year is a lot cheaper and less of a hassle than rebuilding a head.
Platinum
Snake Oil indeed. Toss a few ounces of Marvel Mystery Oil in the tank and you'll have both the warm-fuzzy feeling that you've "done good" and saved a BUNCH of money. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
RickB
RickB
I already use MMO in my dash pots.
I think it does good, therefore it does! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
I've replaced the 20 year old oil & filter now and replaced the cap & rotor and plugs and wires. This is all in my B btw.
I also turned the adjusters on the bottoms of the SU's up a couple of flats. It was running pretty rich.
I know it could use a full tune up of the carbs, but it's cold out there and it is running really good right now! This engine really appreciates a little TLC /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Vroom Vroom!
Platinum
I think I've put about every oil known to man in dashpots at one time or another. Mineral oil, cod liver oil, 30W, 3-in-1, MMO, etc. Now they'd get whatever is goin' into the crankcase at the time.
I've stuffed a 40mm Weber DCOE on it now, so no more dashpots to fill. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
kcbugeye1275
Gotta like the vRooom!!!! I vote with the snake oil, but if you like the snake oil and it makes you feel better. I vote for a sixpack of brewskies. Here is to the holidays.
racingenglishcars
Dashpots don't care what oil. They are only for fuel enrichment upon acceleration.
MMO works great in the fuel system especially on diesels. Keeps the injectors from sticking.
Lead additive... Not for me. Yeah, could be cheap, but then it puts lead into the atmosphere. There was a reason the stuff was discontinued.
https://www.mindfully.org/Pesticide/Lead-History.htm
And I'm not convinced of the damage to the engines (except MAYBE slight seat wear). That could be just as much a myth as so many other things.
RickB
RickB
I remember as a kid I would sometimes get to go up on the hillside above the city where I lived. There was always this kind of green layer to the sky, a little later when I started doing a some traveling I found that greenish layer of air above all cities I visited. That greenish layer of leaded air is gone now, and that has to be a good thing.
Lead killed the Roman empire. They cooked with lead pots and pans and slowly poisoned themselves.
You would think we would learn from history, not merely repeat it over and over.
On the upside, the car ran great this morning except I leaned out the carbs too much. It was below freezing here so that cold air taught me something. I'll richen them a bit at lunchtime.
fabmandan
Donn, it's not lead, it's lead substitute. It does what lead used to do but it's more enviromentally friendly.
S Gas additive, Lead Substitute - BJ8 Austin Healey 9
D Lead additive Jaguar 12
drambuie looking for a good lead fuel additive Austin Healey 5
jaybird Lead additive Spridgets 13
2 Lead Additive Triumph 6
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
Rut Lead for bodywork Spridgets 5
Sopwith_Camel lead lights Jaguar 6
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
rjc157 TR6 Lead Substitute Triumph 5
S Austin Healey LEAD replacement in gasoline Austin Healey 4
aeronca65t Lead East this weekend [in NJ] Other Cars 0
M ignition coil high tension lead connection Spridgets 10
B TR2/3/3A I'm going to try some lead repair. Can I do this to my doors? Triumph 9
J Lead my gas..? Austin Healey 3
B Lucas lead 'helmet-type' battery cables Austin Healey 5
tri_carb_healey leaky lead carb Austin Healey 6
JamesWilson Holes- Lead Loading Restoration & Tools 0
K Zinc and Lead Again? Triumph 15
L Valve seats and lead [substitute]. Spridgets 18
B Lead on xj6 series 1 / Chevrolet 350 Jaguar 0
bcbennett Radio antenna lead Triumph 3
Tr4dude How does a paint chip lead to this? Triumph 13
7 neat tool to make your own lead hammer. Restoration & Tools 10
vping MGB Lead Seams - '63 MGB MG 4
JamesWilson Can Aluminum be Lead Loaded? Restoration & Tools 3
K Lead/Tin 50/50 Triumph 7
prb51 Valve seat recession/ lead substitute Triumph 2
74WannaB Lead work on 74 B MG 3
J TR6 anyone have a lead on a body tub for tr6 Triumph 2
J TR4/4A Anyone have a lead on a wiper switch for a TR4A? Triumph 8
S Lead or octane boost? Austin Healey 3
T TR6 TR6 died - moving plate earth lead fired Triumph 15
AweMan Soldering Lead and Silver Restoration & Tools 10
G Red Lead Primer Triumph 5
R Lead substitute Restoration & Tools 13
jlaird Todays question, no lead head Spridgets 7
mgbmedic about lead substitutes... MG 16
R Lead-Free Cylinder Heads Austin Healey 10
Mark_Gibson Wedge A Good Lead on TR-7's and 8's for Sale Triumph 2
DerekJ #6 Plug lead arcing Austin Healey 4
D no lead cylinder head conversiom Triumph 7
Mark_Gibson Another British Parts and Service Lead Triumph 0
Y Lead Substitute Austin Healey 1
G Lead Head Knock-off Hammer Austin Healey 10
aeronca65t "Lead" Fuel Additives? Restoration & Tools 21
K TR2/3/3A A gearbox additive? Triumph 3
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
Joe Schlosser Transmission Additive Spridgets 8
