TR4/4A Anyone have a lead on a wiper switch for a TR4A?
jessebogan
Like I said... Anybody have a lead on a wiper switch for a TR4A? I have tried all the usuals, and no dice. The lucas number is 35521. Any help gratefully accepted.
TR3driver
Great Pumpkin - R.I.P
I forget Jesse, is that a single-speed or two-speed wiper ?
J
jessebogan
The 4A is a two speed unit. I have several NOS or gently used single speed switches. The 2 speed is like hens teeth.I am doing this car for a customer, so I would like it to be correct. When it came in , it had a household lamp switch in it, and that just will not do. Some one else took the interior apart(with explosives from the look of it), and several parts are missing. I also need the "back" of the grab handle that is molded into the RH lower dash cover. What a mess!
Geo Hahn
Isn't it the same switch as the headlamp switch used on TR4s (and many other applications)? If so, one of those would likely be more plentiful.
TR3driver
It's not the same switch; there are several Lucas switches that look nearly identical but are different inside and/or have different terminals.
However, I believe the TR6 heater blower switch (which may be the same as the TR4 headlight switch) can be made to work correctly and looks almost identical.
The information I have handy shows three wires to the switch : black (ground), red/light green (low speed), and brown/light green (high speed). Connect the black wire(ground) to terminal 4; R/LG to 7 and N/LG to 8.
That will give low speed as the first position out and high as fully out; which I'm not sure is correct. Maybe someone else knows ?
Geo Hahn
Moss lists the same P/N for the TR4 headlamps & the TR4A wiper... but that may well be just a consolidation of parts (sometime in the past as both are NLA now).
Goodness knows there are a lot of lugs on the back of the headlamp switch with (I think) at least one combination unused and I would think if it can handle the draw of headlamps w/o a relay it would be stout enough for wipers.
I should add, it is just barely able to handle the headlamp draw.
TR3driver
TR4 said:
Could another 2 speed switch be made to accept the proper knob?
Maybe, but probably not. The TR4A switch has an unusual connection pattern, with two terminals connected for low speed and all 3 connected for high speed. Most American switches (and the TR6 according to Dan Masters) work differently.
J TR6 anyone have a lead on a body tub for tr6 Triumph 2
Basil Anyone remember Dave Russell? Austin Healey 9
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 35
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
Basil SS100 anyone? Jaguar 5
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
R General TR Anyone going to TRA in North Georgia? Triumph 0
R Wanted Anyone have one of these? Triumph Classifieds 6
mt10flyer TR2/3/3A Anyone race prepped a TR3? Triumph 3
Rut TR4/4A Sorry Top anyone? Triumph 0
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
Gliderman8 TR2/3/3A A nice ORIGINAL TR3A resto project if anyone is looking Triumph 3
