about lead substitutes...
mgbmedic
Hi everybody! I have a question...what do ya'll use for lead additives in your pre-leadfree cars. Years ago, I had found a product that was concentrated, had a measuring chamber built into the container and was quite handy as you didn't have to purchase a new can everytime you filled up. And that gets expensive. Next summer I will rebuild with the hardened valves, but until then I'm stuck with using additives. What products do you use and the sources would be appreciated.
Keoke
HI mgbmedic, Real Lead or CD-2 are good products to keep the exhaust valves lubricated. However, if you are planing a no lead head upgrade in the coming summer you probably do not have to do anything in the interium.--Fwiw--Keoke
tony barnhill
Great Pumpkin - R.I.P
I probably put 3,000 miles on my '67 GT every year - never converted the head, always use unleaded gas....of course, I know that at some point I'll have to put a different head on it...but I've been doing it for more than 5 years now - since they stopped selling leaded gas - with no problems!
I know, I know...
R6MGS
Like Tony, I also usually neglect to add lead...I used to in my red MGA but this year I didn't even burn a tank of gas in it so didn't bother...The White MGA is driven daily all summer but my wife usually ends up filling it and then I forget to add the substitute...As for the B's two have been in storage almost since they stopped selling unleaded(driven a few times a year to keep things alive) and I can't be bothered to add the substitute in the LE for the few hundred miles it gets a year......So far no problems with any of them and none of the heads have been changed(as far as I know, actually the LE might have been).
Nunyas
if I'm not mistaken the '80 B should be ready to use unleaded gas in "stock" form... Actually, North American 74.5 and up should be able to use unleaded in stock form... or is there more to it than I know?
mgbmedic
mgbmedic
i believe your'e right, nunyas. My 76 B needs no additive, but the 69 is an all original car. I just want to protect my little investment as much as possible.
R6MGS
Thanks Rob, thats good news...one less thing to worry about.
Platinum
nehheh... read the post and said to meself: "TEL?!!? Antisocial! Illegal! Politically Incorrect!"
Then read the link'd site. At the very bottom was the disclaimer: "Due to EPA regulations this product is for off road use only."
...and CAT coverters everywhere breathe a sigh of relief.
jlaird
But you know, no where does it say how much to use to save the valves.
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[/ QUOTE ]
A quote from the website:
"12 ounces of OS130 to 20 gallons of fuel provides the minimum amount of lead protection needed to maintain and lubricate engines designed to run on leaded gasoline."
Don't know if this "saves" the valves or not.
LLAngus
Then my 73 ahould need additives? I have a replacement head that went with the car. Might have to change valves over. Id there a marking on the head to tell what year they are from so I can see if the other head is a unlead head?
jlaird
Guess old eyes, I missed that comment on the site, thanks. Hmm, that's only 3oz per tank. cheep enough.
Dave Russell
Yoda - R.I.P
A couple of very comprehensive tests showed that there is little need for "valve protection" with unleaded gas. On engines run at full throttle for extended periods of time, even without hardened valve seats, the valve seat recession was very little. For all out long distance racing hard valve seats may help. This type of engine is frequently rebuilt anyway. Under more normal load conditions, the recession was not measurable.
However, shops do make good money converting valve seats & lots of snake oil is sold at high prices to prevent a nearly non-existent problem. The choice is yours whether you want to spend extra for additives.
Dave Russell
Yoda - R.I.P
[ QUOTE ]
Hmm, that's only 3oz per tank. cheap enough.
[/ QUOTE ]
I guess so if your tank takes 5 gallons to fill. That's only about $1.00 extra per tank.
Platinum
[ QUOTE ]
However, shops do make good money converting valve seats & lots of snake oil is sold at high prices to prevent a nearly non-existent problem...
[/ QUOTE ]
/ubbthreads/images/graemlins/iagree.gif Been running the MG on unleaded for 60K on a rebuild using 'standard' bits for the head. No additives. pulled head last year to inspect, R&R head gasket prior to Weber fitting: Nothing to report.
jlaird
Well maybe this lead stuff is an old wives tail.
Way back when "Pure" brand gas was touted as haveing no additives and we used it all the time. 1950s era.
Just one more reason to wonder at what is said and passed along as fact.
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
S Gas additive, Lead Substitute - BJ8 Austin Healey 9
Rut Lead for bodywork Spridgets 5
D Lead additive Jaguar 12
Sopwith_Camel lead lights Jaguar 6
M TR2/3/3A What Lead Substitute + Octane Boosters is everyone using in there gas tanks? Triumph 14
rjc157 TR6 Lead Substitute Triumph 5
S Austin Healey LEAD replacement in gasoline Austin Healey 4
aeronca65t Lead East this weekend [in NJ] Other Cars 0
M ignition coil high tension lead connection Spridgets 10
B TR2/3/3A I'm going to try some lead repair. Can I do this to my doors? Triumph 9
J Lead my gas..? Austin Healey 3
B Lucas lead 'helmet-type' battery cables Austin Healey 5
drambuie looking for a good lead fuel additive Austin Healey 5
tri_carb_healey leaky lead carb Austin Healey 6
JamesWilson Holes- Lead Loading Restoration & Tools 0
K Zinc and Lead Again? Triumph 15
L Valve seats and lead [substitute]. Spridgets 18
B Lead on xj6 series 1 / Chevrolet 350 Jaguar 0
bcbennett Radio antenna lead Triumph 3
Tr4dude How does a paint chip lead to this? Triumph 13
7 neat tool to make your own lead hammer. Restoration & Tools 10
vping MGB Lead Seams - '63 MGB MG 4
JamesWilson Can Aluminum be Lead Loaded? Restoration & Tools 3
K Lead/Tin 50/50 Triumph 7
prb51 Valve seat recession/ lead substitute Triumph 2
74WannaB Lead work on 74 B MG 3
J TR6 anyone have a lead on a body tub for tr6 Triumph 2
RickB lead additive? Spridgets 9
J TR4/4A Anyone have a lead on a wiper switch for a TR4A? Triumph 8
S Lead or octane boost? Austin Healey 3
T TR6 TR6 died - moving plate earth lead fired Triumph 15
AweMan Soldering Lead and Silver Restoration & Tools 10
G Red Lead Primer Triumph 5
R Lead substitute Restoration & Tools 13
jlaird Todays question, no lead head Spridgets 7
jaybird Lead additive Spridgets 13
R Lead-Free Cylinder Heads Austin Healey 10
Mark_Gibson Wedge A Good Lead on TR-7's and 8's for Sale Triumph 2
DerekJ #6 Plug lead arcing Austin Healey 4
D no lead cylinder head conversiom Triumph 7
Mark_Gibson Another British Parts and Service Lead Triumph 0
Y Lead Substitute Austin Healey 1
G Lead Head Knock-off Hammer Austin Healey 10
2 Lead Additive Triumph 6
aeronca65t "Lead" Fuel Additives? Restoration & Tools 21
Thor Sound/Heat Mats substitutes Spridgets 3
