I can't believe what just happened
2wrench
Paid a Pro mechanic to look at timing on Dyno machine.
Gave him the specs for the BP 270 cam.
Watched in amazement (thinking I was learning something,
here,) while he pulled each spark plug wire on the dizzy
cap and moved them over one to the right.
He just changed the firing order, right????
Then he sets my timing at 24 degrees whichever way, before
or after TDC. Car has vibration on acelleration.
Tells me my carbs are leaking raw fuel. That I agree with.
Hoped I could get by without rebuilding them.
Quotes 800-plus to rebuild and set carb. The car is burning
fuel like a house on fire before he worked on it.
If the carbs need rebuilding, I suppose I should consider
a new set of SU's.
Money is a factor, again.
I'm thinking to walk those spark plug wires right back
where they started and put the timing back more like it
was and start over with a different mechanic. I know
of a good one, it's just the travel and getting his time....
oh, yeah, and the expense.
Any suggestions?
prb51
2wrench,
Last I looked getting a couple of carbs rebuilt by the top 4 isn't close to that much money.
Why did he change the firing order??
Andrew Mace
Moving each wire one spot to the right doesn't change the firing order per se, but it would effectively advance the timing about 60 degrees. Presumably he compensated for much of that with his resetting the timing. Without being there, though, I've no idea why he might have gone to all that trouble.
As for the carb rebuild, shop around. You can probably find a cheap round-trip flight to Joe Curto's shop, where you could hand-deliver your carbs, watch Joe work his magic, and then bring them back home with you, all for less than $800. ;-)
TR3driver
Great Pumpkin - R.I.P
Moving all the wires one post doesn't change the firing order; just the timing.
Under what conditions was the 24 degrees measured? If that is initial advance, it's huge. If it's total advance at, say, 3500 rpm then it seems a little low (which might be appropriate for your engine).
Not sure offhand which carbs you are starting with, but it should be well within any DIY's ability to get them to stop leaking raw fuel (unless a casting is cracked or broken). Unless you need to tackle the throttle shafts, a "rebuild" is pretty trivial. Hopefully I don't need to point out that leaks can waste a HUGE amount of fuel, not to mention being dangerous in more ways than one.
So, my suggestion is to get the carbs to stop leaking first. If these are ZS carbs, then the most likely problem IMO is just crud caught in the float valve. Try cleaning it first, then replace if necessary. Ideally you should have a rebuild kit on hand, but I'd tackle that even without new parts available.
For the timing, get a timing light. A basic, inductive pickup, DC powered timing light shouldn't cost more than $20-30 and IMO is a required tool for old cars. While I have nothing against the expensive computerized ones, the basic tool will do. This one looks like a good candidate
https://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=3343
Now you can check the advance yourself, and try different settings to see what the engine likes.
But fix those carbs first !
2wrench
2wrench
That was the initial advance. He says the overall advance at 2000 rpm's
is putting it at 44 degrees.
14dna
2wrench
Am I confused or is this a new (rebuilt) engine?
The only reason I can think of for doing that, (moving wires) is to compensate for a bad timing chain.
In 44 years of this business, I've never had to do that.
JMHO-LOOK FOR A NEW GUY!
Dave :savewave:
2wrench
2wrench
Yeah, Dave, new rebuilt. I think I will look to somebody else.
I have a mind with Randall's comments to buy the carb rebuild kit and
go for it.
The Forum has kept me pretty good so far. I mean, the darned thing
starts and runs....
I was advised to stay away from the tranny so I did. If Randall thinks
I can do the carbs, I suppose I'm game for a try. After the engine,
why not?
I just always thought carbs were pretty tricky.
NickMorgan
Could it be that the HT leads were struggling to reach the spark plugs with the correct timing and by moving them they fitted better? Otherwise I can't think why he would have done that. Did you ask him?
Yes, try rebuilding the carbs. You will find that it is a quite easy and satisfying job.
2wrench
2wrench
[/quote
I suppose to change the timing. Had me baffled, but I'm
still just a baby mechanic.
This is my "I need a laugh," cup for coffee. I'm pouring me
one....
TR3driver
Before we beat up too badly on this guy, perhaps we should ask if that includes tuning on the dyno. This is a modified engine, after all, so some tweaking of the mixture throughout the range would likely be helpful. I doubt that is included in a mail-order rebuild.
Not that it's a requirement, just wondering if we are comparing apples to oranges.
TR3driver
Well, have a look at Nelson's articles on the subject (assuming you have the stock ZS carbs). These are by far the best, clearest articles I know of.
https://www.buckeyetriumphs.org/technical/technical.htm
But keep in mind that you don't necessarily need to do everything that Nelson describes (including the throttle shaft stuff). Almost certainly your problem is just the fuel level being too high, which is only controlled by the float and float valve.
And the problem might not even lie within the carbs (especially if both of them are doing the same thing). Could be the fuel pressure is too high for some reason. Dale isn't the only one to find a "new" fuel pump that put out too much pressure!
poolboy
It would be a good idea to determine if you can where the gas is leaking from.
If the engine is not running and you see gas dripping from the bottom of the float chamber then it may just be the O-ring seal.
If you see gas coming up the jet when the engine is running, then I'd suspect the needle valve like Randall suggested.
Regardless, I agree that with the help of the Buckeye link that you can replace all the parts that need replacing and more, including and recommended, the throttle bypass diaphram for under 100 dollars
Rearranging the plug wires ? So now either cylinder #5 or cylinder #4, depending upon which direction he went, is firing instead of #1 ?
2wrench
2wrench
In terms of why he did it, he indicated to me that the wires attached to the dizzy
were stopping him from putting the dizzy where it needed to be. He suggested also at
one point removing the tach cable, as if to ask what I thought. I said cool. Don't know if he actually disconnected that tach cable or not. Seemed like he was going to, but then moved spark plug wires, instead. If he took it off, he sure put it back on very quickly.
TR3driver
Which makes perfect sense, in terms of getting the static advance that high. Of course, you could accomplish the same thing by taking the pedestal apart and moving the gear by a tooth or two, but swapping the wires is quicker (and cheaper).
TR3driver
Oh yeah, good point. I forgot about that O-ring.
kodanja
ILL DO IT FOR 750. LOL
2wrench
2wrench
Brosky said:
I hope that you didn't pay him any money.
Sorry, Paul. Yeah, paid $45 for half-hour machine time.
Found a spark plug wire off, after taking a look. Car ran
better, but still doesn't seem to have the push after
3000 rpm.
Bob Claffie Would you believe --- Spridgets 14
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
S Can't Believe I'm Doing This Other Cars 20
2billydavies TR2/3/3A just removed the pistons/sleeves... can't believe she ran as well as she did! Triumph 6
K TR2/3/3A NGK BPR5HS spark plugs I believe are one stage hotter.... Triumph 5
drooartz Just ordered me a new Jeep, there is a logic to it [though none believe me] Other Cars 13
AngliaGT Can't Believe that it's Been Three Years..... MG 3
rkep01 I can't believe that it's finally begun Spridgets 10
Morris I can't believe it! Spridgets 3
mgnewbie I can't believe I broke the head bolt! MG 8
roscoe Not going to believe this one. Austin Healey 2
T I can't believe it - daughters B-day gift Spridgets 12
2wrench Can't believe I broke my rotor Triumph 12
regularman I believe a blind man, might be able to see my... Spridgets 14
T would you believe... Triumph 9
V I can't believe my eyes! Triumph 14
Adam58 You'll never believe... MG 4
bugimike can you believe this? Spridgets 6
H Well you are not going to believe this!!!!! Spridgets 11
vping Can't believe I fit my 1972 Midget in.... Spridgets 18
Brosky I can't believe the difference in the speed!! Triumph 19
jaybird WHOA! Another BCF first I do believe! MG 11
DrEntropy MGB What th' heck happened to Payen?!? MG 17
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
C TR6 A lot has happened. Update on my project Triumph 7
B Colored bulbs at top of page - What happened to them? Austin Healey 3
Got_All_4 General TR This Happened Twice [TR6 tranny in a TR3] Triumph 17
Got_All_4 TR2/3/3A Need measurement from front to rear axels something weared happened today Triumph 7
KVH General TR What Happened to My Leaf Spring's Nyloc Nuts? Take a Look . . . Triumph 17
Morris So this happened... Spridgets 23
WillR MGB What happened to a simple engine refresh? MG 12
tr6nitjulius What happened to Barn Find 1966 E-Type 4.2 Coupe? Jaguar 0
P TR6 What happened to my TR6 picture? Triumph 1
KVH What happened to all the threads between "today" and November 6? Triumph 6
SilentUnicorn I am not sure what happened... British Motorbikes 5
PAUL161 WHAT HAPPENED? PRINT WENT small! MG 3
KVH What Happened to my Triumph? Triumph 9
S What happened to the DMH Museum at VIR? Austin Healey 4
69sprite ...and then a miracle happened Spridgets 13
T What happened to the Triumph graveyard post? Triumph 11
BobbyD How It Happened......... Triumph 12
jlaird What happened Spridgets 2
Baz It Happened! Spridgets 8
NickMorgan What's happened to TVR TVR 6
Brosky TR6 The inevitable happened, my wife drove the TR6 Triumph 11
Sarastro Here's what happened to the clutch... Spridgets 1
PeterK What happened to Spring? Triumph 12
G Capt Roy, Capt Roy, what happened to astronaut? Triumph 4
