Update. A while back I made a post about a strange intermittant drive train lock-up I was having with my 100. I won't bore you with the details. Finally it got frequent enough so I could actually do a little trouble shooting. It seemed that when it happened the shift pattern felt abnormal and I couldn't get it into any gear until, after a bunch of wiggling of the shift lever, all of a sudden the problem was cleared and off I'd go. I finally said to my wife, damned if it doesn't feel like the little swivel on the bottom end of the shift lever is somehow popping out of the cup in the selector fork. But that could never happen... could it? Yup. I had two gaskets on the stack up of parts that hold the shift lever into the gearbox, both rubber,one very think and one fairly thin. It turns out that the thick gasket was raising the shift lever retainer up too high. The bronze swivel WAS actually coming out of the cup on the selector fork and by wiggling it around it would eventually find its way back in place and off I' go. I was lucky that it didn't fall off the end of the lever. I used a thinner gasket, torqued it up and it hasn't happened since. I can not begin to tell you which gear was not lining up so as to cause the gearbox to lock-up, but it must have been ugly. For some reason unknown to me this never happened at speed. I think it took going into reverse or going from 3rd to neutral while coming to a stop(we all wiggle the lever to be sure we're in neutral)for it to happen. I won't be pulling my gearbox this winter. Yessss...
