How to replace door windows on a 77 MG Midget
77midget
I am not computer savvy but I know a nut from a bolt.
This subject may have already been posted but I don't know how to find it.
I took the car apart a year ago using a Robert Bently workshop manual.
While taking the doors apart, the windows somehow disengaged from the regulators and I was able to remove everything. Body work and paint job have been done and I've started putting it back together.
Any suggestions on how to reengage the windows to the regulators and in what order?
The manual makes reassembly sound simple, jut do it in reverse order of disassembly.
Administrator
Boss
You posted your question in the Forum Navigation Help forum - where you ask questions related to how to navigate the forum, post pictures, etc. I am moving your post to the Spridget forum, where you are more likely to get lots of answers.
JPSmit
the bottom of the windows slide into the regulator - you will see a gap - Grease the slide and, if I recall correctly, the regulator needs to be loose in the door to get the window in - then locate it and tighten it in place
65_BRG_Sprite
I just reinstalled mine mine a month or two back. I used the article as a partial guide also, but I don't believe there is anything that can tell you exactly how to do it- you just have to work it out. I found it very, very frustrating until I hit the right positioning of the entire assembly. Patience, patience, patience. A liberal spraying of white grease on the inner face of the door skin will help reduce scratching the new paint while sliding in the mechanism. Installing the seals is what drove me nuts- I never could get the clips to work and ended up using a 3M adhesive sealent.
nomad
The seal clips can be a headache. Somewhere there is a picture of the factory tool but I made one up out of 1" by 1/8" with a "J" bent into the bottom. A little masking tape to hold the clips while you are positioning things helps as well.
Kurt.
77midget
Guys,
Thank You, Thank You, Thank You for all of your help. Taking the whole car apart was difficult and I should have kept better notes and pics.
Reassembling the doors is like listening to the smell of the color red or playing grab-asp with a ghost!
77midget Hendersonville, TN
F Replace 1500 Door Fuzzy Weather Seal Triumph 3
D replace outside door handle Jaguar 4
2wrench What tools best suit interior door skin replace? Triumph 8
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
V MGB Replace late intake manifold angled breather with early model straight? MG 1
W replace rigid master cylinder lines with flex. Spridgets 2
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
B A plan to replace BE floor pans Spridgets 0
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
R TR2/3/3A Replace wiring harness in steering column Triumph 61
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
R TR4/4A Master Cylinder Corrosion Do I replace? Triumph 4
J TR2/3/3A replace brake and fuel lines? Triumph 4
J TR2/3/3A Replace rusty sills? Triumph 10
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
JPSmit replace shocks in pairs? Spridgets 7
JPSmit When do you replace things? Restoration & Tools 22
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
AUSMHLY When to replace spark plugs Austin Healey 1
drooartz MGB What to replace when engine is out MG 10
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
AHS BJ8 blower motor switch - how to replace? Austin Healey 1
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
TRMark TR4/4A Replace Water Curtain Triumph 5
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
S Replace original suspension for shocks? Austin Healey 2
J Replace the outside skin on a cargo trailer??? Restoration & Tools 0
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
S Replace seal and dust cap BJ8 steering box. Austin Healey 23
gbtr6 TR6 TR 6 Head Studs, replace? Triumph 3
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
B Radiator - repair or replace? Pics attached Austin Healey 20
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
mailbox General Tech Fix, replace or rewire? Triumph 8
Kleykamp TR2/3/3A '61 TR3 Horns repair vs replace Triumph 15
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
britlover proper tire size to replace 5.90-15? Austin Healey 16
Rob Glasgow Replace clutch disk? Austin Healey 8
S TR4/4A Replace or rebuild heater control valve? Triumph 5
