TR2/3/3A how to position pieces when painting
sp53
I am looking for some suggestions on how to position pieces when painting the fenders, the hood and trunk on the sides, front, and back. I am probably going to use some burlap painter’s cloths for a back drop and paint inside with the panels on a plywood table. I forgot who suggest the burlap, but I like the idea. I tried some plastic and that attracted to too much dust.
Moreover, can I put paint right over epoxy primmer on the backside of the trunk and spare tire panel. The surfaces look, clean, smooth and flat.
bobhustead
For the fenders, I nailed uprights to sawhorses and hung the fenders from the tips of the uprights. Bonnet was hung on nails thru the Dzus holes. Apron was lain on back on plywood table, as was deck lid. Spare cover was on plywood table elevated from behind. All inner surfaces were flat on plywood. Mask inners from outers as needed to satisfy time between coats requirements.
Paint goes well over epoxy. If cured more than seven days it needs to be lightly sanded per manuf. instructions.
TexasKnucklehead
I used anything on hand to provide a stable support for anything I was painting. Two 4'x8' long old sliding closet doors (arranged like saw horses) made a great stand and allowed all 4 fenders to be painted at the same time (2 on one side, 2 on the other) as the trunk, hood and doors on other stands. I thought it was better to have the panels somewhat on edge, rather than lying flat, since I'm not that good at painting, and it's easier to have runs or paint too thick when the panels are flat. You don't have to think about anything falling off the air hose, or hitting the panel with the air hose, when the panel is not lying flat. I've heard you risk having different batches of the same paint produce slightly different colors, so it's not a bad idea to paint as many adjacent parts as possible, at the same time/mix. -Of course, it's hard to create enough stands and have enough room to paint everything at once. I had no serious dust issues on the plastic tarps I used -I painted in my garage with the door open and a large exhaust fan in the rear pulling air thru the garage. (But I did have one large bug do his death march across fresh clear-coat.) Pay attention to the details in the sheets that came with your paint regarding time between coats etc. and don't forget personal protection. I found it better to cover my arms completely (even tho it was very hot) because after a few days of using lacquer thinner to clean paint off, my arms were not happy. Clear-coat is by far more difficult than color as it gets everywhere and you can't see it, but everything gets sticky.
In retrospect, I liked the painting portion of the restoration, and I'd never used an air sprayer/HLVP gun before. I do remember having a bit of trouble with the left front fender... I think I sanded and repainted it (with color) more than a few times. Be sure to not mix different manufactures products.
DavidApp
I am reaching the same part of my restore.
I am planning to use my rolling stand and anything else I can get to hold the panels upright at a convenient height to paint. I have heard that you should paint as many adjoining panels together as possible because you can get slight colour differences batch to batch from the same can of paint.
I have noticed that I got more top coat paint over spraying on my arm than the primer coats. I went to Harbor Freight and got a paper painters suit that is one piece with a hood. Cheaper than the Big Box stores.
David
S
sp53
Well I combined the idea you guys gave me, and now I think I have a workable system. I will keep my fingers crossed.
DavidApp
Looks good.
I am going to re-purpose my frame stands as panel stands. A few 2 x 4s and I should be able to support all the panels.
David
ChrisTR2TR4
Jerry
I used my wife's house ladder too. It is still a red color! Anything that props the parts up is fair game!
Jerry
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
P Pedal Position Adjustment Austin Healey 2
A TR2/3/3A Seat position Triumph 2
Healey Nut Seat Base Frame Position Austin Healey 4
Jeepster Clutch Pedal Position Austin Healey 4
chicken Inner Door Seal Trim Position Austin Healey 6
B Roof vent position on BN7 hardtop. Austin Healey 15
G Valve adjustment and easiest way set cam position Austin Healey 15
steveg TR6 TDC - Position of rotor and wires Triumph 4
L Seat position for a BN1 Austin Healey 0
Upland 3 position headlight switch is now 2 Spridgets 1
J TR2/3/3A Front apron position Triumph 9
D AH 300O MK1 Choke Knob Position Austin Healey 5
G BJ7 Window channel position Austin Healey 1
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
D TR2/3/3A Dipper switch position Triumph 13
W Cam gear position BJ8 Austin Healey 11
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
E TR4/4A TR4 Radiator position with Macy's garage Fan Triumph 6
S TR6 Position of the buffer wedges under the hood [ bonnet] on a 74 TR6 Triumph 2
S TR4/4A Ignition switch key position Triumph 2
J TR4/4A Horn clip position. Triumph 6
P bumperettes position BT7 Austin Healey 8
K TR2/3/3A Correct position for flasher bracket? Triumph 7
N TR4/4A no spark in start position Triumph 8
gbtr6 TR6 Help! Starter runs with ignition in on position Triumph 18
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
E TR4/4A TR4 Throttle shaft position Triumph 1
R TR2/3/3A Position of LTD fastener on new top Triumph 5
M Accelerator Pedal Position Austin Healey 4
J TR4/4A 175 CD needle position? Triumph 5
TRclassic3 TR2/3/3A SU Upper jet bearing position Triumph 5
2billydavies TR2/3/3A dumb question of the day: engine fan for TR3a position Triumph 11
A TR2/3/3A TR-3A steering wheel position [measurment needed] Triumph 3
Gliderman8 TR6 Starter energizes when in RUN Position...... Triumph 17
vette Seat floor position Austin Healey 10
B Spin on oil filter position Austin Healey 1
P Interior door opening handle position Austin Healey 11
Tinkerman Wheel Knockoff position Triumph 7
T Spitfire Grease slinger position on a Spit 1500 axle Triumph 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
S XKE Accelerator Ppedal Position Jaguar 2
CanberraBJ8 no.1 cylinder position in Distributor? Austin Healey 2
M Wheel and Axle position Spridgets 12
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
richberman Bonnet release handle on BJ8 position Austin Healey 10
R TR5/TR250 Tr4, 4A and 250 gas cap position? Triumph 6
AUSMHLY Does your window rattle when in the down position? Austin Healey 3
chicken Quarter light position to high Austin Healey 2
