TR2/3/3A How bad is this? Vertical link
Snowkilts
Just wondering what you guys think about this vertical link.
About half the threads are somewhat deteriorated. Maybe it rusted under the care of a PO?
With the threads fully engaged I can wiggle the trunnion .010 in using the setup in the photo. But it seems like when held by the ball joint there is little or no opportunity for the link to move in this direction? I'm not seeing any noticeable play in any other direction.
I also checked the run-out of the upper bore (for the ball joint) with the threads chucked in the lathe and got around .050 in.
LarryK
Personally, I would replace assembly, new if possible, good used if not. I like non-corrosion, especially the way I drive.
Deleted member 8987
One of my vehicles uses .... 14 trunnions. Now has 12, but that was a vintage repair.
Looking at that, yes, some rust, but I sure have seen wear (like lots of driving and no lube jobs) on the steel threaded bits.
Junk.
Replace.
TR3driver
Great Pumpkin - R.I.P
+1 on replace. There's lots of margin, it will probably be fine if you don't go jumping other cars or whatever, but not worth taking a chance IMO.
M_Pied_Lourd
+3 replace.
Cheers
Tush
TomMull
I don't know if these are as prone to snapping off the way they are on neglected Heralds, Spitfires, etc., but having experienced a snapped trunnion on a Spitfire while in motion, I'm +4 on replacing!
Glad I didn't know that when I did a half dozen fairly quick laps, for an aging dead stock Herald, on a race course last summer. (Our Club got a free ride)
Tom
Here's the course: https://clubmotorsports.com/course
TRopic6
I would expect the rust-roughned threads to wear down the brass trunion every time you made a turn. Should be some good used out there; early TR4s used the straight v-link as well. Jeff
Andrew Mace
For some reason, it seems more prone to happening at low speeds!? In my instance, I was almost at work, having just exited off some rather high, curvy bridge ramps and back down to very low speed coming out of a tunnel...when the LF vertical link snapped at about 10-15 mph! Took a minute or two for it to sink in that it could have happened high above the streets of Albany NY! :shocked::eeek:
S
Snowkilts
Oddly enough, the trunnion looks fine. About half the threads on the link are good, while the ones in the bad area are visibly eaten away from their full thread profile. I suspect the good threads are holding everything in place well enough that the bad threads are not even touching the trunnion.
TRopic6
Hmmm - Interesting observation and your explanation does seem logical. Since they weren't touching, moisture could get in there to rust the v-link.
Jeff
S
Snowkilts
I've been careful about keeping it lubed and there was no red rust on it when I took it out. Looks like somebody in the past cleaned it up and stuck it back in.
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
P TR6 Bad Luck? Triumph 51
jlaird MGB Follow up to my bad post on prewar MGs MG 4
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
T TR2/3/3A bad napa points Triumph 9
S TR2/3/3A Now the bad news. BRAKES Triumph 7
Alfred E. Neuman TR4/4A Bad news on my TR4 Triumph 8
D TR2/3/3A Bad parts. Triumph 16
charleyf TR4/4A Symptoms with bad condenser Triumph 14
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Overheating Bad Triumph 12
roscoe Good news/bad news Austin Healey 11
Rut Help a bad memory out... Spridgets 6
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
C TR6 Frame Pics, some bad news Triumph 9
M TR6 Fresh rebuild gone bad!!!!!!! Triumph 13
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
S Is it a bad idea to buy a higher pressure radiator cap? Austin Healey 47
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
gbtr6 TR6 Good news, Bad news Triumph 10
JFS TR2/3/3A Bad Water Pump Triumph 11
P TR2/3/3A "MaXpeedingRods" con rods good or bad? Triumph 3
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
D Removing servo . Good or Bad Austin Healey 12
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
Sixpack TR6 Bad Oil Leak Triumph 24
tinman58 TR2/3/3A Bad thinking? Triumph 25
Geo Hahn TR2/3/3A Bad Day in the Garage Triumph 23
tinman58 General Tech Bad spark plugs Triumph 7
J The Good the Bad and the Ugly Lotus 4
DanLewis How bad does your Bugeye need a boot? Spridgets 6
bighealeysource How to color sand really bad orange peel Restoration & Tools 6
D Spitfire '65 Spitfire MKII w/bad vibes Triumph 4
T is my generator bad? Austin Healey 5
T TR2/3/3A Sticker idea; good or bad? Triumph 11
pkmh Distributor rotor gone bad more than once. Austin Healey 5
PAUL161 Moss Motors T Series Parts - Bad Gaskets! MG 5
Boggsy64 MGB Brit are bad engineers MG 17
M My '65 suddenly started running bad today Spridgets 37
HealeyRick Bad Day on the Hill in NZ Austin Healey 7
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
bertl Bad Surgery Triumph 7
J Bad News 1098 Spridgets 14
John_Mc Probably just a bad ground somewhere... Triumph 1
I Effect of bad valves on engine performance? Triumph 9
J How bad do Spridgets leak oil from the crankshaft? Spridgets 18
I Anyone have a bad voltage regulator for a bugeye? Spridgets 2
