Help with tranny overdrive leaking
AUSMHLY
Has anyone had any luck minimizing the leakage from the transmission and overdrive in a BJ8?
What thickness' are the gaskets suppose to be?
1. Transmission Gasket, case to clutch housing.
2. Overdrive Gasket, overdrive to gearbox.
3. Overdrive Gasket, plate to casing.
I believe the original overdrive gasket, plate to casing was red colored. I think it may have been thicker than the other two gaskets? (This is the area, gasket that leaks the most.)
I think (and that usually gets me in trouble)that the gaskets moss and BV sells are all 1/64 tan colored. (for 1,2 and 3)
I've shopped locally for a thicker make your own gasket. What I've found is a roll by NEA products. Description: Asbestos free, high temperature gasket material. #1967. Size 12"x 20"x 1/16" Easy to cut / E-Z to use for automotive applications such as EGR and carburetor mounting gaskets, water pumps, water outlets, oil pumps, fuel pumps, etc. Do not exceed 350 degrees F.
My Transmission/overdrive mechanic and I are spending a lot of time r&r the unit. Seems the problem is the aftermarket gears. Seems to shift ok on the bench, but not when under load in the car.
Current problem, 1st and 2nd pop out. Tried using washers between the selector shaft ball and spring, and one washer in the layshaft. Lots of pressure to get it in, and a nice click sound saying it's in. Then it slowly moves itself towards neutral and pops out of gear. We've ordered Denis Welsh's first gear with sliding hub. (ouch, that's pretty penny).
Anyway, back to the leakage. I'm still leaking, after using new gaskets. The current gaskets don't seem to be doing their job. My feeling is they are not thick enough, or the leak is from the studs/bolts. I've heard some people say try using "The Right Stuff" sealant. https://www.permatex.com/brand_right_stuff.htm
My mechanic and I are leery of using something new. Going with the tried and true paper gasket. But then, it may simply be tried and true that they leak. Try something new? Has anyone used The Right Stuff on the tyranny/overdrive?
Cheers, Roger
Try this:
You'll never look back :wink:
Yes, but I don't <span style="font-style: italic">eliminate</span> the gaskets, I still use them with just the slightest film of sealant. Applied properly, you'll barely see any squeezed out from the mating flanges.
At the present time, my car doesn't have an overdrive (MGC xmsn fitted) but I use that flange sealant on BMW differentials frequently (closest thing I have to a day-job is working on M Coupes/Rdstrs at home__see: www.rfdm.com/gallery).
C TR2/3/3A Need Help Identifing Tranny with Overdrive Triumph 4
histerical Datsun tranny help please Spridgets 18
E IIA Tranny help Rover / Land Rover 3
G Looking for tranny & rear end help Triumph 3
Tabcon TR4/4A Help with front input shaft seal on TR4 tranny. Triumph 3
M Help! What's wrong? Tranny or clutch? Spridgets 12
Tinkerman Rear tranny flange retaining nut removal. HELP!!! Triumph 8
R Help with instillation of heat shield on tranny Austin Healey 4
G TR2/3/3A Quick Help - taking the cover off a TR3 tranny Triumph 3
A TR4/4A Mysterious TR4A tranny noise [that vanished] -help Triumph 7
M Spitfire Need HELP on Spitfire Tranny upgrades Triumph 1
KLUTZ Help me line up Tranny mount... Please MG 1
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
