Gear lever thread size
RobWarren
Folks,
I'm looking to get a new gear knob for the BJ8, in stainless steel - a plain sphere. I suspect that if I get a modern-made one I'll neeed it to be tapped to fit the thread on the lever.
Anybody know what size the thread is?
Bob
GregW
I put my own knob on using a modern threaded sleeve insert. I think it was 3/8" coarse thread?
John Morralee
measure the outside diameter of the male thread then lay a ruler along the theaded portion count the number of Threads Per. Inch resulting in for example: 3/8 ins. O.D. 12 TPI this thread size will be recognised as a standard by any machine shop. Job Dun.
PAUL161 Gear Shift Lever Thread Size? MG 28
S Gear Shift Lever Travel Austin Healey 13
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
Rob Glasgow Wanted Austin Healey Gear Shift Lever Austin Healey Classifieds 2
W Gear Lever Boot for BN2 Austin Healey 5
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Michael Oritt Gear shift lever modifiacation [No Healey Content] Austin Healey 7
Rut 5 speed gear shift lever Spridgets 28
Rut MGB MGB OD gear shift lever MG 0
6 Gear Shift Lever Spridgets 3
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
M TR4/4A Gear lever plunger and spring Triumph 7
M Stag Wiring plugs for gear lever knob overdrive switch. Triumph 1
RedTR3 TR2/3/3A Trans Gear lever interference Triumph 0
F Adjusting gear lever, centershift 3000 Austin Healey 2
T TR2/3/3A TR3B gear shift lever Triumph 6
bighealeysource BN2 trans gear lever getting stuck Austin Healey 8
brgrmyster GTG6 Gear Shift Lever Inner Ferrule? Triumph 0
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
davidk Gear Shift Lever Vibration Triumph 4
Tinkerman Gear shift lever threads Triumph 21
jpr28056 Gear shift lever twisting Spridgets 10
Tinkerman TR2/3/3A TR-3, Pitting on gear shift lever ball. Triumph 2
L T-Series Gear box servicing cap. MG 5
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
B Transmission Gear Lockouts Austin Healey 8
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
S For Sale Differentail gear sets available. Spridget, Morris Spridgets Classified 12
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
C Spitfire gear selection Triumph 10
JPSmit Gear reduction starters anyone? Restoration & Tools 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
DocDup1 TR4/4A Second Gear Bushing Triumph 6
