Gear box oil
apple0154
Having just purchased a Midget I found out the previous owner put 80 oil in the gear box instead of the recommended 20W50. Should I just drain the oil and refill with the proper grade? Any problems I can expect?
JPSmit
welcome - please repost this over on the Spridget board - Sprite + Midget = Spridgit.
My 1500 uses gear oil but I'm not sure what the effects would be on a 1275 transmission
rggav
Member
If the transmission had been upgraded it would use a different weight oil. I just had the Moss five speed transmission installed in my MGB and it uses 75W-90 gear oil not 20W50 like the official manual states.
Platinum
If its a standard BMC trans, drain it and use motor oil. Your laygear will thank you.
Roger
Bronze
20-50 oils, or any other over 40wt, aren't subject to the same additive restrictions as lighter oils. So they're closer in formula to oils of old, with respect to stuff like ZDDP, etc., though still retaining the benefits of lubrication technology progress.
Read Castrol's write-up on their Syntec full-synthetic 20-50 for example. It's on their
Web Site.
One thing the original poster didn't state is if this is chorme bumper car or the Triumph engine rubber bumper car, if it is chrome bumper MG engine car, then motor oil in the gearbox, if it is the 1500 then gear oil in the gearbox.
Sorry I should have ask you that from the get-go, than assume it was a CB car.
JPSmit
it is Hap - '74 from his profile
JPSmit
Boatin said:
Whats a Triumph 1500 engine in a rubber nose. ? Never heard of that one.
Final run of Midgets (rubber bumper cars) 75-80 used the 1500 engine from the Triumph Spitfire as it wasn't worth British Leyland adapting 2 engines (1500 & 1275) for the smog regulations of the USA and especially California.
Joe_Healey TR5/TR250 Overdrive Gear box oil Triumph 8
J TR2/3/3A Gear oil in the gear box? Triumph 13
J Healey Gear Box & OD oil Racing 5
ekamm gear box oil Triumph 13
W Silly question Gear Box oil change/top up MG 11
LuckyLuke Right Oil for BN1 axle and gear box Austin Healey 4
R MG MIdget 1500 gear box oil changing MG 0
R MG MIdget 1500 gear box oil changing Spridgets 13
A TR4/4A TR4 gear box oil Triumph 13
W MGB MGB GEAR BOX OIL. MG 7
tahoe healey gear box/ OD oil Austin Healey 6
L T-Series Gear box servicing cap. MG 5
Todd78d Sprit MK1 gear box filler Spridgets 2
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
D Socket for TR3 Gear box drain plug Restoration & Tools 6
F BN1 vs Bn2 gear box Austin Healey 23
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
Got_All_4 General TR Problem mounting the a type to the gear box Triumph 12
K TR2/3/3A Gear box to Motor Bolts? Triumph 6
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
Got_All_4 TR2/3/3A Removing the J type unit from the gear box Triumph 24
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
D gear box fill plug Triumph 13
andrea $ SPEED SIDE SHIFT GEAR BOX Unknow spare piece Austin Healey 3
tahoe healey Gear box woes Austin Healey 10
ekamm TR2/3/3A Tr3 steering gear box removal Triumph 6
Got_All_4 TR2/3/3A Prize in every box! TR3 gear box Triumph 30
W Over drive gear box MG 0
J Gear Box Jaguar 10
tahoe healey Fillintg the gear box on a BJ* Austin Healey 3
TRnorwegian Japanese gear box better? Triumph 29
R T-Series TC Steering Box Worm Gear MG 1
mountainman TR2/3/3A TR3 STEERING GEAR BOX FLUID Triumph 5
Tinkerman TR4/4A Cluster gear removal TR4 syncro box Triumph 2
J Speedometer housing at gear box Spridgets 2
Tinkerman TR2/3/3A TR3 gear box shaft selectors Triumph 6
Tinkerman Cleaning Tranny, OD and Gear Box Covers Triumph 9
B Gear box whine MG 11
Got_All_4 TR2/3/3A Removal of Steering Box Worm Gear In Car TR3A Triumph 3
M Gasket sealer on bell housing to gear box Austin Healey 13
M Steering gear box zerk fitting Austin Healey 16
tahoe healey big gear box problem Austin Healey 7
A TR4/4A TR4 gear box question Triumph 4
tahoe healey Gear box dip stick Austin Healey 2
R Gear Box/Stick Problems Austin Healey 5
W O/D Gear Box Or Not MG 28
W 5 Speed conversion gear box MG 3
A TR2/3/3A TR3 gear box dismantle question Triumph 1
A TR4/4A Converting TR4 gear box to O/D Triumph 4
tahoe healey gear box drip Austin Healey 7
