TR4/4A TR4 gear box question
Alex_McMillin
Hi Everyone,
I am having a bit of gear grind happening after my 63 TR4 warms up. When I shift into 2nd or 3rd it will grind if I make a quick shift. If I shift slow, hold down the clutch for a second, it is much better. I don't really know the history behind the tranny and it could probably use rebuilding. Last time I checked the gearbox oil level was ok. Could this be a clutch issue?
Any ideas would be greatly appreciated.
........Cheers, Alex
Geo Hahn
I would start by bleeding the clutch just in case that's all that it needs.
You might 'sit down and take a stress pill' then search the archives for 'broken clutch fork pin'.
Could also be worn synchros in which case a change of lube might buy you some time but will have you into the gearbox eventually.
Kurtis
Do you have a problem with first or reverse? And is the problem on the upshift, downshift, or both?
Alan_Myers
Hi,
Your '63 TR4 should have an adjustable clutch release. Have you adjusted it lately? Should be done annually or every 12K miles, per the service & owners manuals.
A
Alex_McMillin
Kurtis, I have no problem with 1st or reverse. The problem begins after the car has warmed up and when shifting both directions. Upshift from 1st to 2nd, 2nd to 3rd, and downshift from 3rd to 2nd. There is absolutely no problem shifting into 4th. What's your thinking?
I was also about to bleed the clutch system and make the appropriate clutch adjustments as per the manual. I will let you know if it makes any difference.
............Cheers, Alex
I will
Tinkerman TR4/4A Cluster gear removal TR4 syncro box Triumph 2
A TR4/4A TR4 gear box oil Triumph 13
A TR4/4A Converting TR4 gear box to O/D Triumph 4
O TR4/4A tr4 pops out of second gear on deceleration Triumph 13
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
A TR4/4A TR4 Slips out of 3rd gear Triumph 5
KVH TR4/4A TR4 Timing and Distributor Gear Triumph 3
SCguy TR4/4A TR4 gear shift knob Triumph 13
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
