TR4/4A TR4 Timing and Distributor Gear
KVH
I'm almost ready to "button up" my distributor after installing a new timing chain and tensioner. I've dropped the distributor gear down onto the cam gear and lower distributor bush. I'm looking for the classic offset angle where the slot in the gear points to Pushrod Tube No. 1. I can get it just a bit before and a little bit after, but at TDC it doesn't seem to be pointing dead on.
Is this typical? I'm fairly certain I lined the crank and timing sprockets correctly, and valves 7 and 8 seem in balance. I'm definitely at TDC. Should I suspect I'm off on the cam sprocket by a notch, or is the angle of the slot not all that precise. If I drew a straight line I'd be off the center of the Tube No. 1 by 1/4 inch to 3/8 inch.
Thanks.
sp53
I have not done it for awhile, but it sounds like you have something wrong perhaps just a little. If you lined up the marks right on the sprockets that should be fine and make sure you are at TDC with the compression stroke. Look at the valves and see that number one valves are closed when the mark on the pull hits the stationary mark on the timing chain cover. Or Pull number one plug and put your thumb over the hole and turn the engines over and when it pushes your thumb off that is TDC compression stroke. If I remember right, the drive gear only fits in the oil pump one way for it to truly bottom out in its hole, and I think it pretty much points the rotor right to the push rod. The drive gear slides and turns as it goes in also and you might have to get a long screw driver and move the oil pump slot a little to accommodate the slid. Anyways try and start it to see what happens.
JeffS
If I'm not mistaken (and PLEASE correct me if I'm wrong) if the dots are lined up on the timing chain gears, you're on the #4 TDC, not #1. Turn the engine one full revolution and THEN drop in the distributor drive gear.
TR3driver
Great Pumpkin - R.I.P
I believe the "pointing towards #1 pushrod tube" is only approximate; so no harm done if it points a little in front of the tube.
If valves 7 & 8 are on balance (and you have a stock or factory performance grind cam); then the cam is at it's TDC position even if you've installed the chain wrong.
TR4 TR4/4A TR4 Timing Chain Maintenance Triumph 9
T tr4 timing chain-who's is best??? Racing 7
M TR4/4A TR4 Timing, 270 Cam, Pertronics Triumph 3
T TR4/4A TR4 Timing Cover Setup Triumph 3
T TR4/4A Early TR4 - Timing Cover Oil Seal Triumph 3
D TR4/4A TR4 dynamic timing Triumph 17
bluemiata90 TR4/4A TR4 ignition timing Triumph 6
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
