Gas Tank Sending Unit Orientation
B
Bobbee44
I ran out of gas in my driveway (very lucky), after attending Britian on the Green here in Northern Virginia. My gas gage read 1/4...not so. I am reticent to just plop a new sending unit in the tank. I remember reading in one of the threads a caution on orientation of the sending unit in an Austin Healey. I cannot find that thread. If it is an incorrect orientation, then it's a cheap fix, if not....
Bob
BJ8Healeys
You don't say what model car you have, but the BMC Parts Manual for the BJ7/BJ8 shows the sending unit oriented with the float arm forward.
It was the location of the pickup tube that also puzzled me; I "ran out" of fuel on my first test drive in what is now my car. Going up Dolores Street in San Francisco, the car sputtered and stalled, after cars had gone around me, I coasted backwards into a driveway, and sitting horizontal again, restarted the engine. Waiting long enough for the cars to clear on my side of the divided boulevard, I headed back downhill to the next crossing, against the normal flow of traffic...
... and on to a filling station.
When I made the 28 gallon tank currently in the car, I put the pickup tube at the rear; if I'm low on fuel, I'm not opposed to coasing down the hill, being much easier than the other way around.
steveg
I've verifed the following on the bench with a spare tank:
With the float pointed forward as shown in the diagram, it will drop into the well at the bottom of the tank, showing empty on the gauge when the tank is empty.
With the float pointed backward, it will come to rest on the floor of the tank, above the well, thus showing 1/4 tank when the tank is in fact empty.
The sending wire should be coming off the rear of the sender. If it's coming off the front, the orientation is incorrect.
B
Bobbee44
Steve and others:
Thank you all for your help. I am going to pyll the spare and trunk liner out this weekend and take a look at the sending unit and wire orientation. If all is as it should be, then Moss will be selling yours truely a new sending unit.
Bob
B General MG 77 MIDGET Gas tank sending unit MG 1
B Gas tank sending unit float...doesn't float MG 13
H Sealant - Gas Tank Sending Unit Austin Healey 9
cdsmith "sealing" gas tank sending unit Spridgets 8
TomMull GT6 Gas Tank Outlet Triumph 0
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
B TR4/4A GAS TANK FELT Triumph 14
B Damaged threads in the gas tank Austin Healey 7
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
B TR4/4A Gas Tank color? Triumph 4
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
D What's inside the gas tank?? Spridgets 13
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
J TR2/3/3A TR3A gas tank repair Triumph 7
Michael Oritt Gas cap parts now in tank Austin Healey 17
R TR2/3/3A Installing gas tank Triumph 6
FlyingCat Spitfire Gas tank Triumph 2
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
R TR2/3/3A Pin Hole in gas tank Triumph 9
D TR2/3/3A Gas tank does not fit! Triumph 4
C MGB Found this spring in my gas tank MG 8
B Stripped Thread in Gas Tank Austin Healey 26
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
S TR4/4A Worm in gas tank? Triumph 7
PatGalvin TR2/3/3A TR3A Gas Cap Info and uel tank venting Triumph 4
F Throw away BN7 Gas tank Austin Healey 3
F For Sale BN7 gas tank, original. [I think]. Austin Healey Classifieds 0
maxwedge5281 sxplash or overflow when filling healey gas tank Austin Healey 6
AngliaGT MGB Gas Tank Removal - '67 GT MG 2
69MGC MGC New Gas Tank for my C MG 3
D TR4/4A Tr4 Vented gas tank banjo bolt Triumph 7
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
K TR2/3/3A Gas tank pipe connector? Triumph 6
S TR2/3/3A gas tank hole body work Triumph 7
maxwedge5281 gas tank and grill installation Austin Healey 29
K TR2/3/3A Gas tank to pipe connector.... Triumph 1
K TR2/3/3A Cleaning a gas tank with muriatic acid.... Triumph 7
C TR2/3/3A Gas tank cover in cockpit area Triumph 3
J TR2/3/3A Gas tank fitting and ferrule Triumph 2
S TR2/3/3A with sugar in the gas tank Triumph 13
Tinkerman TR2/3/3A Another Freeby from the past. For a 1960 TR3A Gas Tank Triumph 4
Gliderman8 General Tech Cleaning sludge/varnish from a gas tank Triumph 6
