front brake hose 67 BJ8
fordtrucks4ever
My original hoses are getting rather flimsy. The left caliper is starting to drag noticeably. I ordered new hoses and the ones that arrived are different than what I have. The new ones are long and have a banjo fitting to attach to caliper. My hoses are attached to the spindle and frame with short steel line connecting hose to caliper. The hose has same fitting at both ends.
Looking thru an EIS archive catalog that covers years 1926 -1974 show the 3000 and Sprite use the same hose. The ones I have now will fit my 69 Sprite and Bugeye so I will keep them.
EIS SP6263
Centric and Raybestos BH36901
I added these Raybestos hoses in with a larger order for another vehicle to save on shipping, otherwise they would have come from Moss or VB.
Patrick67BJ8
EIS SP6263
can you post photo of your new hoses? Also, very good idea to change the rear hose at the same time.
steveg
This is the ticket:
F
fordtrucks4ever
Close up of both ends.
The originals lasted nearly 50 years, so I am not too impressed with SS lines that cost 3X more than a set of stock ones.
F Front brake hose BJ8 Austin Healey 4
nevets Front brake hose length Austin Healey 10
J TR2/3/3A TR2 - earlyTR3 front brake hose length and photo? Triumph 1
nevets front brake hose question-BN6 Austin Healey 18
S Front Brake Hose Wear Austin Healey 9
kennypinkerton front Brake hose question... MG 5
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
bighealeysource Front Brake Adjusters Austin Healey 0
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A Spacers to centre the the front brake rotor? Triumph 11
John_Koop TR2/3/3A Front brake calipers locking up when pressing on brake. Triumph 18
I Bug eye front disc brake conversion. Spridgets 5
bighealeysource Question on 100M front brake cylinder Austin Healey 4
M TR6 Front Brake Caliper Bracket Part Identification Triumph 0
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
John Turney TR6 Brake Line to Front Calipers Triumph 4
K TR2/3/3A Front brake rotors hot to the touch...... Triumph 6
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
I Wanted Sprite front brake parts Spridgets Classified 1
K TR2/3/3A Front Brake Caliper Shims Triumph 3
T Assistance with Front Brake Lines Spridgets 3
doc50 Met front brake pistons Other British Cars 4
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
AngliaGT Front Brake Dilemma - '74 cb Midget Spridgets 4
R TR2/3/3A Front Brake Conversion Triumph 5
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
G Rover P3 Brake Lining - Front Rover / Land Rover 2
K TR2/3/3A Front disc brake squeal.... Triumph 4
L Front Brake 100/6 Austin Healey 1
R Help with BJ7 front brake line routing Austin Healey 6
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
A TR6 '73 tr6 passenger front brake dragging Triumph 2
spartan0199 BT7 Right Front Brake Drag Austin Healey 30
M Front steel brake lines Spridgets 9
certifiedcarnut 948 front brake shoes warning Spridgets 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
R BJ7 Front Brake disc hitting Austin Healey 12
P Bugeye front drum brake picture Spridgets 7
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
bigjones Front brake job - any advice? Spridgets 94
RJS TR4/4A Replacing front brake hoses Triumph 10
C question on the front brake lines for BJ8 Austin Healey 2
