Final fix for clutch pipe to master cylinder leak??
warwick-steve
Hi all
After fitting a new "can" type brake/clutch fluid reservoir I have lived with a small leak from the pipe from the reservoir where it is screwed into the master cylinder. I would have to top up about every 4 weeks. I decided to try and fix the problem. First I tried using some PTFE tape over the flared end of the pipe. The result was worse. (top up once per week!). Then I replaced the pipe with a spare that I had and the result was no better.
I now presume that the seat in the master cylinder is damaged in some way so I now intend to fit a new pipe and a new master cylinder. My questions are;
- is the replacement of the master cylinder straight forward?
- Anything to note? Any tips please?
One positive thing from this is that I have now got the hang of bleeding the clutch with long nose pliers a 3/8 spanner and an easybleed tube
Thanks in advance
Steve
steveg
If you're using a stainless pipe, the flare may have become work hardened and as a result, leaks. I had that happen after removing the stainless a couple of times. I've gradually replaced all my stainless pipes with cunifer.
warwick-steve
warwick-steve
Hi Steve
Thanks for getting back. The pipes are cunifer. I will try a brand new cunifer pipe again but if that is no better I will fit a new master cylinder and pipe. I just wondered if there is anything I should consider in this procedure as I have never done it before?
Steve
Bench bleed the MC before installing. Be careful to route the line so that nothing, like the flex cable for the cool air vent or an air filter, rubs against it.
steveg
Hi Steve
Steve
If you're making your own pipe, be sure to not squish the second flare too hard. It's supposed to compress slightly when you tighten the tube nut into the seat. With cunifer, you can also anneal the flare by heating with a torch or gas burner until it turns red, then allowing it to air-cool.
Addendum: annealing could possibly restore one of your old flares enough to seal.
Rob Glasgow
I have always wondered how you bench bleed the clutch master cylinder and then get it installed in the tight area on the bulk head without spilling any of the fluid all over everything. It seemed impossible to do. Can someone please explain?
silicone plugs in the ports until you get the tubes fitted.
warwick-steve
warwick-steve
Gentlemen
Thanks for the information.
I guess bench bleeding is to ensure all the air is out of the MC and replaced by fluid before connecting up and making the final bleeding process easier..
For this purpose I would do it on the car using the old/existing pipe from the reservoir to the new MC and use a spare pipe and connection at the outlet of the MC. Once the MC is bled I would fit the new MC and a new pipe from the reservoir.
I do regret now throwing the old reservoir away as it would have been useful for bench bleeding off the car.
Please excuse this possibly stupid question but is it possible that an already used and leaky copper/cunifer pipe flare end could damage the seat in the new MC. I presume that as the pipe is softer than the mc alloy casting this cannot happen??
On fitting the new MC are there mechanical adjustments to be made at the pedal linkage?
Thanks again.
Steve
roscoe
Do not be sceptical of using a bright light and a good magnifying glass to inspect the seat in the port. If there is any scoring, dents, or galling ( which is when displaced metal is "smeared" or balled up) you should be able to see it. If it looks good it probably is fine. If you can use a macro function on a digital camera and view a photo on a good computer screen it is sometimes even better than direct view; if your resolution is high you can blow it way up on the screen.
Gentlemen...
Thanks again.
Steve
I don't think a cunifer pipe flare would damage the seat in a steel (iron?) MC, but when mating a pipe to a seat the final 'forming,' if you will, is done when you tighten the fitting. That is, the flare of the pipe would have been formed somewhat to the seat of the previous cyl. This may be more of an issue with steel lines, as cunifer is softer, but there is a chance you would get a leak.
Just check the play on the pedal when you're done and adjust if necessary. While you're under the fascia twisted like a pretzel check the pin on the brake and clutch trunnions; they're usually worn and it's a quick job to take some of the slop out of the pedal.
steveg
The MCs are aluminum.
The seat is protected - unlikely to be damaged. Seems more likely a problem with the pipe flare or the tube nut is cross-threaded or stripped.
If you're going to build/buy a new feed pipe, might consider trying it out on the existing MC before going to all the trouble of installing a new MC.
The MCs are aluminum. ...
That's what I thought, too, until I received a steel--or iron, I really can't tell--one from Moss, I think, years ago. Wasn't happy with the horrendous weight increase (;)), but it's worked fine for years. IIRC, it came in a Lucas box, but who knows where it was made. Yes, the original in my BJ8 was Al, as is the clutch MC.
warwick-steve
warwick-steve
Thanks Jon, Steve and Bob,
I am going over to AH Spares tomorrow and will pick up a new feed pipe. I will also pick up a new master cylinder on a "just in case" basis. I will fit the new feed pipe to the "old" master cylinder and hopefully it will cure the leak. Steve the thread looks OK so it must be the flare. ( currently the clutch fluid level is dropping 1mm a day)
I am so looking forward to bleeding the thing yet again!!
cheers
Steve
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
Bayless Ready for final block sanding Spridgets 5
R TR6 1973 Final drive issues Triumph 5
pbraun Bug i nearing final completion Spridgets 11
CJD TR2/3/3A TR2/3 Guru Final Exam Triumph 59
J Final painting detail questions Austin Healey 16
B Final painting of all body panels - with panels on or off car? Pros and Cons? Austin Healey 7
DornTRoriginal TR2/3/3A Final Check Items Restoration nearing completion Triumph 9
MadMarx TR4/4A [VIDEO] NĂĽrburgring RGB Seasons final race Triumph 12
dougie SOVREN Fall Final PRW Racing 2
B Final MARRS race of the season - free admission Racing 0
Pythias 1275 Transplant --- Final Report Spridgets 4
Jim_Gruber Bugsy's Final Goodbye Spridgets 4
KVH Final Testing of OD Triumph 2
glemon Final Rocker Shaft Question Triumph 5
F Final touches- a few detail questions for a BJ7 Austin Healey 11
hondo402000 Stag TR6 Engine rebuild in final stage, dyno date 7=22 Triumph 23
PAUL161 MGA Doc, Do You Know MGAs final gear ratio? MG 11
hondo402000 TR6 TR6 Final Paint pics and Putting it back together Triumph 31
drooartz Progress: garage space and the final list Spridgets 3
Tinkerman TR2/3/3A Final drive ratio for TR 3A Triumph 8
MadMarx [Video] RGB Seasons Final Nurburgring GP Track Racing 7
mikecyc72usa The final push Triumph 0
ncbugeye What tool to remove final drive filler plug? Spridgets 12
dougie HMSA Portland Historics 2009 Group # 7 Final Racing 4
zimmy 74 midget..............final price drop! Spridgets 7
ncbugeye Final drive on Bugeye Spridgets 17
SilentUnicorn The final straw Spridgets 26
reinaldo Stag Final stage in the restoration of my TR4A Triumph 23
Brosky Under windshield frame and final prep for paint Triumph 6
Brosky Final panel fitting & new mirrors Triumph 38
PATR8 Wedge TR8 repair mostly final tally Triumph 40
Brosky New Engine, the final chapter Triumph 3
Glen_B My final Ozark slide show Spridgets 1
regularman Well, just placed a final [hopefully] order Spridgets 8
JPSmit final question [tonight] - cleaning transmission Spridgets 5
bcliff Stuck Intake Valves.. The Final Chapter! MG 4
B Final Exhaust pics Spridgets 26
J Weber final adjustments-I hope Spridgets 2
T Final Timing Question [I hope] Triumph 10
M Rear axle [final drive] tools or information Restoration & Tools 5
billspohn Final Jamaican Pictures MG 22
regularman Can anyone tell me what the exact final ratio is.. Spridgets 15
jollyroger Sprite Parts Vortex final closing deals. Spridgets 0
A E-Type rear suspension/final drive continued.... Jaguar 4
David_K **Final Interior Combo Choice** Austin Healey 39
Simon TR4a Final cleaning before paint. Restoration & Tools 3
J MG plays its final act..[its sad and final] MG 3
Bruce Bowker eBay B - final price? MG 18
