Nope... can't do the Geranium.( especially now that I've seen some good pics) It dosen't look bad, but I just don't like it very much. My Tr2 is not all original anyway. the original engine is gone. in its place I have a TR4A engine and full syncro Trans, (from a 66 I parted out) and the TR3 front plate to make it fit. Also TR3 intake and SUs to fit under the bonnett. It's already been givin the later TR3 rear axle somwhere along the line, and I will be fitting it with TR4A disc brakes, and probably master cylinder, for some added safety.
and the front apron is actually an small mouth TR3 apron that will be modified slightly to be the correct TR2 style (trim around opening, grill attaching points)
So, 100% originality is already out the window. I don't do the whole show thing...I drive. My kind of trophies are the clollection of bugs and chips in the paint, the brake dust in the spokes, and the worn out pedal pads. I do want it to be visually accurate from the exterior though. at least as much as possible. So I'm still open to fender beading stuff.
I guess with the proper flex additive the PVC beading would hold paint ok. Most of the "chipped" beading I see is stuff that was painted because it was too much work to keep it from getting painted. Not that it was really on purpose.
