TR2/3/3A front fender bead screws?
TexasKnucklehead
My car didn't have any fender beading when I got it. Both front fenders have small holes (about #8) that I suspect will align with the tab under the hood of the new front fender beads. If I am to secure the beads to the fenders with screws, what size/shape head are the screws? Are they threaded or self-tapping? Is it possible to put a nut on the inside of the fender?
I understand the curved section will be secured by the tabs -just like the rear fender beads.
Although I will be busy tomorrow and not able to work on the TR3 most of the day, this is the kind of thing that keeps me awake at night...
TR3driver
Great Pumpkin - R.I.P
Mine didn't line up that well, perhaps because it's an earlier car, so I had to drill some new holes. Since the unused holes in the fender would be hidden, that's where I put the new ones (to match the holes in the new bead strip).
I believe the screws are supposed to be YA0183, which are #4 round head sheet metal (self-tapping) screws, 3/8" long. I used that size (in pan head instead of round) and they seemed to fit well. It might be possible to put nuts on them, but what a PITA.
PatGalvin
Thank Jerry for the question. I also needed to know this as I'm starting to attach beading now. Thanks Randall!
Pat
TR3driver
Slotted.
mallard
I don't think the TR3 has any Phillips screws in it. I agree with Randall #4 round head screw.
TR3driver
I believe the originals were slotted, as John said. Mine are Phillips because those were the only replacements I could find at the time.
Moseso
The only Phillips screws I found on my '59 -- and they could be un-original, but don't look it - are the two, each side, securing the red plastic lens to the tail light base.
CJD
Hmmmm....mine slotted there too!
The only Phillips I remember we're the screws holding the windings in the generator and starter. And maybe a couple in the headlight assemblies, but can't remember there for sure?
mallard
John you got me on that one, the generator (dynamo) does have the Phillips screws.
vivdownunder
Seem to recall the red plastic lens had slotted screws up to TS46360, thereafter Phillips head. Wide mouth grille screws were Phillips head.
Viv
mountainman TR2/3/3A TR3 Front Fender Bead Triumph 2
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
M TR2/3/3A Front Inner Fender Doublers Triumph 2
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
L TR2/3/3A Scuttle / front fender attachment Triumph 9
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
S T-Series front fender MG 1
R TR2/3/3A Securing the front fender beads Triumph 11
O Need front driver's side fender 65 Midget Spridgets 0
B TR2/3/3A seam sealer front fender and cage muts, undercoat Triumph 7
S TR2/3/3A tr3 front fender Triumph 4
charleyf TR6 Plate on drivers side front inner fender Triumph 6
S TR2/3/3A Patching the front fender Triumph 8
Tinkerman TR2/3/3A Front Fender Installation Tips Triumph 3
T TR2/3/3A Question on shape of lower back of front fender Triumph 7
Brinkerhoff Front fender RH BN2 model needed Austin Healey 2
luke44 TR2/3/3A TR3 Front Fender Washers? Triumph 19
E With frame on level stands my drivers front fender is 1 inch higher than the pass? Austin Healey 5
Lin Right Front Fender Removal - 60 BT7 Austin Healey 2
J Front fender flex ??? Triumph 15
T Front Fender Corrosion Triumph 5
wangdango BJ8 front fender removal? Austin Healey 8
M 100-4 BN2 Front Fender with extra Groove Austin Healey 2
R 100-4 front fender removal Austin Healey 2
A Material between front fender and tub Triumph 15
M Is this hole in the front fender original ? BN2 Austin Healey 6
luke44 TR2/3/3A TR3 Rear Fender Alignment at Front Edge Triumph 8
G Advice needed in removing front left fender. Triumph 2
A TR2/3/3A TR-3 LEFT front fender Triumph 6
mountainman TR2/3/3A TR3 Front Fender Alignment Triumph 5
bighealeysource Installing front fender stainless steel beading Austin Healey 4
R TR6 Late TR6 Front Fender Removal Triumph 5
CraigLandrum TR2/3/3A heck is a TR3A front fender... Triumph 6
B Removal of front fender on BJ7 Austin Healey 14
J front shroud to fender welt Austin Healey 4
RickB MGB MGB front fender alignment question MG 6
zimmy 74 front fender removal Spridgets 2
N Removing Front fender MG 4
Lin Mounting the RH front fender [wing] Austin Healey 0
T TR4/4A Moss TR4/5/6 front fender patch question Triumph 2
HAN8L1965 Need Right Front Fender 65 Sprite Central Ohio Spridgets 5
R BJ& front fender/door seal. Is there one? Austin Healey 2
D TR2/3/3A TR-3 Front Fender lower patches Triumph 5
R Front Fender Bolts...Uggghhhh! MG 5
MgKid1974 Need Front Left Fender Please! MG 10
H Front Fender Variances - Big Healey Austin Healey 2
S MGB Left Front Fender needed for '75 MGB MG 0
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
