robert_ellison said:
When installing chrome fender bead is it correct to fold the tabs on the beading over the fender (or shroud), or to just push the tabs down between the loosely bolted fenders and then tighten the bolts. When trying by folding I am having difficulty with the bead staying in place when fitting the fender to the shroud, before bolting.
When I did mine, I had the fender on and bolted fairly snugly, but loose enough for the tab to slide up & down.
I grabbed the bead tab with a pair of pliers and pulled down HARD.
Then, without releasing the pull on the tab, and still holding the pliers VERTICAL, I swung the pliers sideways towards the FENDER.
When I had the tab sharply folded over the fender lip, I pushed UP.
The tab has the shape of a letter "Z" on its side. Sort of like this " |/| ".
Then tighten the fender and as the fender moves toward the shroud, the fender and shroud lip will close very tightly against the bottom of the bead.
It worked for me. 10 years later, my beads are still tightly against the shroud and fender.
Tim
