TR4/4A Engine mount questions
Sarastro
A couple simple questions:
1. In the TR4A frame, there are two holes where the engine mounts could be installed. When I tore down my TR4A, the mounts were in the rearmost set of holes. Is that correct?
I ask because there were some indications that the engine was too far back--but if it were, I think the holes in the transmission wouldn't line up with those in the trans mount, correct?
2. I noticed there are two mounts used in TR4s and 4As: a round one and a square one. My car had the round mount, which I assume was the correct one. When were the square ones used?
In other news, my frame is now finished and I have started mounting parts on it. That's a milestone, I think!
Popeye
Bronze
I believe the rear hole is the correct hole; this is how mine was. I have not put my car back together yet, but am not sure there is enough play in the rear axle, driveshaft and motor to allow the "wrong" hole to be used??
I used the rectangular mount, as that is what I had. Not sure what is original to the car / correct. The spare parts catalog calls for p/n 130985; the round one sold by TRF. Moss claims round is for TR4, square for TR4A, but not sure how correct that statement is, given the spare parts catalog calls out the round.
Congrats on the finished frame! Mounting parts to it is fun; just don't let people see you sitting where the driver's seat goes, making "vroom vroom" noises!
Sarastro
Sarastro
Thanks for the response. Probably won't get any more, but it's good to have some confirmation on the mount location. As for square vs. round, it is just curiosity; no practical need to know.
pa297pass
Not definitive of course, but my 1962 TR4 had the round engine mounts when I took it apart. I have no reason to believe they weren't original to the car.
Matt
Geo Hahn
Is it difficult to change the fan belt on a TR4A? It is on a TR4 because of the very tight clearance between the crank hub and the steering rack. I added some shims under the motor mount to raise the engine about 1/8" which has seemed to have been okay and allows the belt to slip thru there more easily. I also shimmed the radiator a like amount to make the upper hose aligned correctly.
This was with the round mounts -- so for shim I just used matching diameter washers (bi washers) from the hardware store.
Wolfy
I have mine in the rear holes. I changed over to the round type of engine mounts seen on Land Rovers and other vehicles as they handle loads in all directions well. I know others have also done this mod with positive views.
charleyf
I use the round engine mounts on my two TR4's. The mounts that I got about five years ago were weak and flexed and leaned a whole lot. I did find some better ones at TRF that seem to work a lot better. I almost changed over to the rectangular ones just to get better support.
Charley
Sarastro
Sarastro
Thanks. I did get the TRF mounts, and they are now on the frame. Might be quite a while before I have the engine ready to stick back onto them, though.
J TR2/3/3A Engine mount Triumph 5
M TR6 TR5/6 Engine Mount/Chassis Brackets Assistance Please. Triumph 2
Bugeyze Engine mount advice please Austin Healey 9
G Wanted Packing pieces on rebound rubber engine mount Austin Healey Classifieds 0
G Packing pieces on rebound rubber engine mount Austin Healey 5
RCarr BN1 Engine Mount rubber parts Austin Healey 4
D TR4/4A square engine mount washer necessary? Triumph 6
TulsaFred Engine Install motor mount question Spridgets 5
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
Kleykamp Transmission/engine mount removal Triumph 4
brgrmyster GT6 GT6 Engine Mount "Spacers" - What's the Purpose? Triumph 2
L Engine Mount Thickness for Bugeye, etc. Spridgets 1
S T-Series How do we mount a TD engine on an engine stand? MG 7
Jim_Stevens Engine front mount replacement Triumph 3
glemon TR5/TR250 TR250/6 engine mount Triumph 2
M 76 Midget Engine Mount Replacement Spridgets 1
K clutch slave engine mount Triumph 13
J New engine mount set up Austin Healey 0
Tinkerman Engine Mount Spacers ?????? Triumph 10
J TR6 best way to mount the TR6 on an engine stand? Triumph 3
kyreb1862 77 RB Engine Mount Problem MG 1
B TR6 TR-6 Engine Lifting Mount Bolts - Leaking? Triumph 12
J Engine Mount replacement Triumph 14
David_K Painted engine mount buffers Austin Healey 3
D Spitfire Engine Mount replacement in a Spit... Triumph 3
Bruce Bowker Alfa Side mount engine Other Cars 4
mrv8q TR2/3/3A TR3 Water pump/Engine mount advice Triumph 2
T MGB '79 MGB engine mount replacement question. MG 0
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
