lesingepsycho
OK. The new engine is in the car and been through all the appropriate steps but I'm still having some major issues.
<span style="font-weight: bold">The Issue:</span> Smoking like crazy; blueish smoke, smells extremely rich, can't tune it out
<span style="font-weight: bold">The Knowns:</span>
1)ALL BRAND NEW ENGINE
2)Good compression all around - All 4 at 150psi on my gauge
3)Dead on timing, timing adjustments make no difference
4)Carb adjustments make no difference
5)Spark plugs are DARK brown and DRY, NOT oily, all 4 match
6)O2 sensor is DARK brown and DRY, NOT oily
7)Head torqued and retorqued & valves adjusted and readjusted at .014"
8)Low-ish vacuum reading (see Camshaft)
<span style="font-weight: bold">The Variables/Possibilities/Considerations:</span>
1)Camshaft is an Elgin Racing cam for a turbo or supercharged motor. Currently I'm running carb only, no boost (Weber DGV). 286 degrees duration/66 degrees overlap/110deg lobe centers IO:33deg IC:73 EO:73 EC:33 0.303" lift
2)Newly refreshed cylinder head but I'm not quite sure about the stem seals. I know that it has new valves, seats, springs and retainers but I'll have to find the receipt to see what/if anything else was done.
3)This was odd; With exhaust and intake manifolds off, cranking the engine produced puffs of dark gray/blueish "smoke" at the exhaust ports.
4)It's like it is not getting a complete burn, even when the O2 sensor is telling the gauge it is running lean. But I don't necessarily trust this O2&gauge combo. Just a guideline.
I'm at a loss guys. I'm at the end of my rope. I don't have the turbo setup ready for the car yet but I thought I would be able to run on this motor without the turbo. This is my daily driver and it has been out of comission for 3 weeks now. Luckily I can get to work on my bicycle. I really need a car though so any input will be greatly appreciated.
JACK
JACK
