Electronic ignition?
laneriddle
I have a 66' Austin Cooper S that I've rebuilt pretty much stock. I was considering upgrading to electronic ignition,as it's suppose to be more efficient and more reliable. the car runs good and hasn't broken down yet,would this upgrade be worth the effort and expense? If so,what type ,brand, is the best? Thank you for any input .
Jerry
I put the 123 ignition in mine. Has lots of settings to choose for your motor. Works well, starts well. I never had points in this car so I can't tell how it compares. I put electronic in all the cars I have worked on. Just like it myself. You can go Pertronix or fancier. I picked this 123 because I did not have a distributor to start with.
Jerry
https://www.123ignitionusa.com/MG.html
dklawson
As Jerry said, it is a question of what you are expecting and what your budget is.
If you generally like the way your car drives and are only looking for modest improvements in starting and steady running, the Pertronix Ignitor module is reasonably priced and reliable. Google for "retro rockets ignition" and you will find one of the most economical online vendors to buy from. The Ignitor module is easy to install. Most people who run it carry a spare set of points and a condenser in the boot so should it ever fail for any reason you can re-install the points and be on your way.
The 123 distributor is as Jerry said outfitted with several electronic advance curves. You use a switch to select the one you feel is best suited to the build of your engine. If you haven't made any major changes to your engine then it may be overkill. I have only heard a few complaints about 123. They primarily involve the cost and the availability of replacement caps and rotors.
There are some other systems out there. The Crane ignition is an optical sensor technology with a remote amplifier/switch box. They are reliable but not as stock looking as the Pertronix which all fits under the stock distributor cap. In various cars I have used the Crane system, Pertronix, and am currently running a converted Hitachi distributor from a Nissan in my Mini. I don't think you will regret switching to electronic ignition.
Elva164
I used Pertronix on my Spitfire 1500 for three years and it started every day, all year. It seems that failures occur more frequently in higher-stress situations like high temperature/racing conditions. Carrying points and a condenser is a good peace-of-mind measure though.
That is another point: I can't comment on the reliability of the other methods mentioned here, but an "advantage" of Pertronix is being able to remove it and either replace it or swap back to points/condenser without removing the distributor.
dklawson
We have run the original Pertronix Ignitor module in my father-in-law's vintage Formula-Vee for years without any problems. On street cars I anticipate the largest problem of the original Ignitor module (not Ignitor II or Ignitor III) is that they are sensitive to overheating. The overheating can be caused by an unaware owner leaving the ignition in run for about 5 minutes with the engine NOT running. If you avoid that (and knowing about the problem is all that is required to be alert and avoid it) then Ignitors are fine on a street engine which is subject to a lot less than a race engine. The Crane ignitions are also robust but require more effort to install. I did manage to destroy a Crane ignition on our GT6 when I decided to wash the engine bay. The old amplifier unit we had was either not sealed or the sealing had failed and water got inside. I doubt that is a problem for current production units.
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
TRickster6 MGB electronic ignition on '73 MGB MG 1
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
O Sprite Petronix Electronic Ignition Spridgets 10
S Fried electronic ignition? Austin Healey 22
F TR2/3/3A Timing with Electronic Ignition Triumph 14
S Wiring connections for electronic ignition BJ8? Austin Healey 3
T MGB Vacuum advance and Electronic ignition conversion MG 5
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
S TR4/4A Electronic Ignition Recommendations? Triumph 14
PAUL161 General MG Crane Electronic Ignition MG 9
S will old style distributer cap work with electronic ignition on AH Austin Healey 8
R Electronic Ignition Distributor Spridgets 14
D Electronic Ignition for 25D distributors Spridgets 15
sundown TR6 TR6 electronic ignition Triumph 10
mountainman pertronix electronic ignition hepl please Triumph 10
D TR6 TR6 Electronic Ignition Triumph 16
T Electronic Ignition Issue Austin Healey 6
B What is best electronic ignition setup MG 19
T Electronic Ignition MG 15
rosalind electronic ignition conversion - advice please? British Motor Corp 3
D Electronic ignition choice[s] Triumph 17
D Rebound straps and electronic ignition MG 2
J Midget 1500 electronic ignition? Spridgets 10
scott_74 Electronic Ignition? Spridgets 15
NardisCNC Electronic Ignition Upgrade Questions... Spridgets 17
C Electronic Ignition Tutorial please? Triumph 20
H electronic ignition systems Austin Healey 11
SCguy Wedge Best electronic ignition for my TR8 Triumph 9
H Plug wires for electronic ignition Austin Healey 18
MGTF1250Dave Pertronix Ignitor Electronic Ignition Installation Triumph 26
T static timing with electronic ignition? Triumph 10
R Electronic ignition Spridgets 5
AUSMHLY Petronix Electronic Ignition positive ground Austin Healey 10
SherpaPilot Best Electronic Ignition? Triumph 9
vette MGB MGB Electronic Ignition MG 2
T MGB Static timing a MGB w/ a Crane Electronic Ignition MG 5
Atrus Yes, another electronic ignition question Spridgets 2
Sarastro Crane electronic ignition installation Spridgets 3
Raymond electronic Ignition MG 20
Atrus Electronic Ignition Comparisons Spridgets 24
JamesWilson Electronic Ignition? Lotus 7
R Electronic ignition Austin Healey 11
tony barnhill NORTON BOYER ELECTRONIC IGNITION WITH COILS &podtr British Motorbikes 4
ChrisS Electronic Ignition Spridgets 5
C ELECTRONIC IGNITION FOR A 3000 ? Austin Healey 12
W Electronic Ignition MG 9
