driving dog [gear] for distributor?
Hawkscoach
First, thank you in advance or any help! Been 8 years or so on this full restoration and we are almost ready to turn the engine over. 59 Austin Healey 100/6 BN4. somewhere along the project, I mis-placed what I believe is the "driving dog" that goes between the distributor (at the base) and the actual gear. My more experienced expert that is helping me with this step pointed out my missing part.
I don't know how to describe it and I cannot find a good picture. Again, Moss describes it as the driving dog. Which, is what I am looking for as I may have it.......there is a pic in Moss that shows it, however, it is small and I cannot see the details (old eyes). if I cannot find it in my "carefully organized" remaining parts, I am worried that it is not available. Please help me get to the next step in this long project.
Regards,
Doug
Keoke
Go to Healey Surgeons there in MD & ask Bruce For help
steveg
If you have to bite the bullet and buy a new one, Moss has these for $175. PN 021-330 on "Internal Engine 100-6, 3000" page".
If you don't have the stock pin you can use a roll pin.
Between the engine block and distributor sits a short tower containing the mechanical tach-drive take off. Do you have this part__fitted at least up to the 3000 MKIII models (pretty sure the BJ7s still used a mechanical tach, but I've been wrong before).
Vent window nut from an MGB (hidden inside door). The extra length makes it easy to keep an open-end wrench engaged, and it's only 3/8" across the flats, easier to get a smaller tool in there!
For the past couple of decades, I've been using this oversize'd wing-nut (source unknown) so no tool required at all!
vette
Yes the BJ7s still have mechanical tach. At least mine does and the set up is as Randy shows it.
H
Hawkscoach
thanks everyone! with the pic (you helped me understand what I was looking for, I was able to locate it in my "unused" stash. All good and moving forward.
H
Hawkscoach
also, just an fyi. I contacted Bruce at Healey Surgeons (he rebuilt my transmission for me a few years ago) and they do have the part if anyone temporarily misplaces it like I did......thankfully, I found it
Keoke
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S Spridget Mountain Driving Tour : Mid-Atlantic Spridgets 8
6 Seeking 1967 MGB roadster in good driving condition MG Classifieds 3
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
T how to have music/radio when driving Spridgets 33
C How to install Stone Guards on driving lights? Austin Healey 7
C Wiring for two front Driving Lights? Austin Healey 22
maxwedge5281 Driving Lights [picture posting opportunity!] Austin Healey 25
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
jdubois GT6 Driving the mainshaft bearing into the gearbox case. Triumph 5
T 100/6 vs 3000 driving experiences Austin Healey 71
Jim_Gruber Thoughts on driving Bugsy with the hardtop installed. Spridgets 32
R Winter Driving Austin Healey 24
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
M Driving/Owning Comparison between TR3 and AH3000 Austin Healey 13
M TR2/3/3A Driving Comparison between TR3 and AH3000 Triumph 40
vette Driving and/or Fog Lamp Bulbs Austin Healey 5
D TR2/3/3A Driving lights / badge bar attachment. Triumph 4
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
steveg Lousy driving light bulbs Austin Healey 0
bugedd Driving to elevation Spridgets 3
Got_All_4 TR2/3/3A Looking for advice in driving a TR3 with overdrive Triumph 6
steveg Healey hot weather driving observations Austin Healey 2
B Distributor driving gear orientation Austin Healey 2
turtle Avengers Assemble! Tony’s Driving a Healey... Austin Healey 1
2 TR2/3/3A Winter driving question Triumph 10
JPSmit Driving on the 401 today Other Cars 5
T TR2/3/3A 1/4 mile fast time driving technique Triumph 15
5 T-Series TF 5 speed conversion AND upgrade 4.55 Rear -- any driving problems? MG 6
bugedd How is your driving weather? Spridgets 12
KVH TR4/4A I Sure Like Driving My Triumph Triumph 8
K Spitfire '78 cuts out after many miles of driving Triumph 8
D Ticking noise when driving Austin Healey 8
anarchy99 Driving season... Spridgets 2
Sherlock It's driving season finally! Spotted 5
Jer 2014 Driving Season... Spridgets 8
S Driving Lamps - how to tighten? Austin Healey 8
AHS TR2/3/3A Resto [almost] finished - first driving impressions Triumph 16
toysrrus TR2/3/3A Lucas "Driving / Fog" Lens wanted: Triumph 9
K TR2/3/3A A cut down side curtain for Fall driving? Triumph 7
RickB Installing flip front kit, what's easiest way to secure back of bonnet for driving? Spridgets 40
S Highway Driving Spridgets 22
vette Driving/Fog Lamps Austin Healey 3
S Summer Driving Spridgets 13
M TR4/4A @ The driving stage with ALOT of minor " fininshes" Triumph 5
T TR6 Brake caliper lock after some driving Triumph 3
