Dragging front brakes
Stewart
I'm dealing with a weird front brake issue. The front brakes will intermittently drag when cold you can feel the slight resistance when moving the car by hand. WHen they are warm they will drag enough to slowly bring the car to a stop and hold it on a mild slope. While driving the pads are being held enough against the rotor to hear them along with that lovely burning brake smell. Both front wheels feel to be at the same temp.
75 mgb with the brake booster
Heres what I've noticed
I can do a couple of hard stops and get the brakes hotter than the sun and they will still work perfectly with out dragging however if I get into city traffic a few stop signs even with cold brakes is enough to get them to start sticking. When the brakes start sticking the pedal goes rock hard. When they stop sticking the pedal returns to normal.
So far I've replaced the calipers, pads, front hoses and even the rotors. I'm I looking at a bad master or something else?
Deleted member 8987
Crack a line.
If you crack the line at the master, and it goes "poof!", and rolls freely, it's the master.
If it doesn't, it's in between.
Start cracking fittings until you find it.
PAUL161
Stewart, If the front flex lines are old, they can separate on the inside and create a valve effect which will cause a pull on one wheel or another. It's rare, but has happened. If that's not the problem, look for the piston in the MS not returning all the way back and letting the pressure bleed back to the reservoir. The hard pedal at times you indicate, makes me feel it's a Master Cylinder problem. JMHO. PJ
Stewart
Stewart
Update
Changed out the master with a new replacement and checked the hard lines for kinks there were none.
With the booster connected felt great for a while then the brakes pumped up and the front started dragging again. Bad enough that you could not move the car using your foot to push with an open door. When the brakes are working normal no effort to do so.
Jacked the car up fronts locked up rear perfectly free.
Cracked the bleeder on the left front it spurted and the brakes released enough to move the car. Front brakes were HOT.
Started the car up and the over the space of 30 seconds the front brakes bound up. Shutting the car down and pumping the brakes to bleed off the vacuum released them.
Disconnected the vacuum from the booster.
Drove the car again and it felt fine for about a mile then the same old feeling of the system pumping up and the rock hard pedal and bound up front brakes returned.
I'm completely baffled.
bob67bgt
Any chance there is no free play between the master and the booster push rod? I know very little about late booster car brakes.
Good luck on the repair! Bob
Deleted member 8987
Back to what I said earlier.
First, don't just throw parts at it, figure out what is wrong FIRST.
When it locked on the old MC (and now new MC), did you crack the line at the master?
Did it go "poof!" and release?
If so, it's the master (or pushrod too long, or some such...identifiable by tighting line, applying brakes until locked, and unbolting MC to icrease free play and see if it rolls).
If that doesn't do it, crack at the MC end of the booster FIRST, if that doesn't do it, crack it at the wheel end of the booster.
Dave
PAUL161
<span style="font-size: 10pt">Check this also for proper operation and internal obstructions! They are reparable! PJ</span>
sparkydave Dragging front brakes Spridgets 4
A TR6 '73 tr6 passenger front brake dragging Triumph 2
britlover Front Drums dragging with adjusters all the way out Austin Healey 5
drooartz New brake pads, wheel is dragging? MG 4
J Drum brake dragging. Spridgets 11
W JagMKII rear brakes dragging Jaguar 13
bobmga62 MGA dragging rear brake on mga MG 3
G Why is The Forum dragging........? Triumph 15
S Am I dragging my A** Triumph 7
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
