MGA dragging rear brake on mga
bobmga62
Hi ...replaced the shoes and the left rear wheel cylinder on my mga.
As I do mileage on the car, it seems to get tighter to the point that the brake is dragging. When I stop, the drum is rally hot, whereas on the right side, just slightly warm...I jacked the car up this AM, to check the adjustment, and the wheel spun freely, (a lot of brake dust) still took a notch or two to relax it, but, it just seems to appear that the brake goes on, and does not release enough under driving conditions...(it does not lock up, and in fact do not feel it under normal driving conditions...so it must be dragging just every so slightly..)
Any ideas...
thanks
bobmga61
MGZT260
Any chance you have a bad wheel bearing on that side? Since initial brake adjustment is performed with wheels off the ground a bad bearing can affect actual operation.
Another thing to consider is the possibility of the adjuster not being held still and self-adjusting when it's not supposed to.
Or, off teh wall idea, did you install new "brake shoe steady springs" from Moss that have a longer tang that needs filed or cut off? If so shoes may not be held properly against backing plate. (see their tech bulletin in online catalog)
bobmga62
bobmga62
your second idea sounds right to me.. its like the brakes (left brake) are tightening up as the trip progresses..and the first thing that came to my mind, was that it was the adjuster.. anyway to fix and lock in?
did check, and the brakes appear to be located correctly, although it was tough to figure out, cause in the manual, the photo is a reverse image than whats on the car (must have flipped the negative in the main workshop manual.. and mine comes back from the original 60's)
I did relax the adjustment in the back a slight bit, and took the car out.. and in reality, I think I have no brakes in the back now..
neither drum was warm, when in the past one was warm, the other hot...
Hey, back when I first had an mga in the 60's I drove it with rear wheel cylinders frozen shut for for two years, before I realized I had a problem...
W JagMKII rear brakes dragging Jaguar 13
A TR6 '73 tr6 passenger front brake dragging Triumph 2
britlover Front Drums dragging with adjusters all the way out Austin Healey 5
drooartz New brake pads, wheel is dragging? MG 4
J Drum brake dragging. Spridgets 11
Stewart Dragging front brakes MG 7
sparkydave Dragging front brakes Spridgets 4
G Why is The Forum dragging........? Triumph 15
S Am I dragging my A** Triumph 7
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
