Although not a permanent solution, jacking up the car by sticking a jack in the middle or the back end of the frame on the side stuck may help to get it open, if anything is binding (one way or the other) the frame flex you create may help open it. The doors mechanisms can be sensitive to amount or lube, I know my TR250 drivers door didn't want to close until I cleaned and greased the mechanism.
