Door Rattle
memphis
Hi All!
May have been discussed before.....
I had a slight rattle in both of my doors when I closed them.
I found and cured the rattle. The spot where it was rattling was between the front window rail (vent post rail) and the door pull rod (not sure if correct name?).
Even with the felt lining on the pull rod, it still rattled. To cure it, I simply slid some of the felt forward, bunching it up in the area between the rail and rod. Not sure if I'll make this the perm solution? Would have to tape the one end of the felt to keep it from sliding back. Also, over time, it may rub through in this "bunched up" area.
Anyone else have any ideas, solutions?
Thanks,
Brinkerhoff
Bob, I have a BJ7 in my shop with the door innards exposed so I'll look. Thanks for the heads up on the rattle or I may have put it back together with a rattle. As long as the bar slides past ok as not to bind the handle . The whole area seems too flexible doesn't it? Kevin
RAC68
Hi Bob,
I had a similar situation with my BJ8P1. When I closed the door, something would vibrate or rattle and it took multiple incursions to determine where and what was vibrating. It turned out to be caused by a slightly loose connection between the door latch and the rod connected to the inside handle. Additionally, this rod would also vibrate against the vertical bar you identified. The cure I quickly employed was a self-sticking piece of Velcro (that just happened to be sitting on my bench) attached to the vertical support.
Seems to be still working.
All the best,
Ray (64BJ8P1)
B Door rattle Austin Healey 0
pan Door Shut Face Panels Austin Healey 0
D Door Lock Tumbler Austin Healey 4
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
LAW75 BJ8 Door Locks Austin Healey 2
Cappy Occasional Door Malfunction Austin Healey 1
nichola TR6 Door handle and window crank installation Triumph 0
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
M Spitfire 1500 LH Door Triumph Classifieds 0
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Door Seal Austin Healey 5
chicken Inner Door Seal Trim Position Austin Healey 6
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
Popeye General TR FS2758 alternate - Door Pull Assembly Triumph 2
G Wanted - Glove Box Door for a TR3A Triumph Classifieds 2
T Heater Door Spring Austin Healey 1
